I was wondering if anyone could grace me with some information. I have been living in the stone ages when it comes to web design and have finally reached out to learn some basic flash.
I am working on a website for a family friend and have unfortunitly found myself in a rutt with part of my flash menu.
The site is www.luxuryincr.com ; If you view the site you will see my primary issue concerning the menu.
For example: If you were to click on "fishing" (http://luxuryincr.com/index-3.html) you will notice that after all the AS occurs, the menu goes to highlight "Home" instead of "Fishing" (which is not what I want to happen). This is a reoccuring issue with numerous of the menu selections. I am pretty sure it has something to do with the AS but cannot get a grip on it.
If anyone is able to help me out, I would be sooo greatful!
________________________________
This is the AS for the "fishing" tab... I am unsure if this is even where the issue is taking place but I figure that there has to be someone whom is a genius in Flash and may be able to point me in the correct direction.
onClipEvent (load) {
num = 4;
this.hitArea = this.area;
on (rollOver) {
if (_root.page<>num) {
this.gotoAndPlay("s1");
on (releaseOutside, rollOut) {
this.gotoAndPlay("s2");
on (release) {
_parent["item"+_root.page].gotoAndPlay("s2");
_root.page = num;
getURL("index-3.html");
Please! Any kind of help would be appriciated!! Thank you!!
Outside of everything just directly call the home
_parent["item1"].gotoAndPlay("s2");
you should be using:
num = 4;
on (rollOver) {
on (release) {
if (_root.page<>num) {_root.page = num; // <-assign before the following code_parent["item"+_root.page].gotoAndPlay("s2");
