9 Replies Latest reply on May 19, 2011 12:21 PM by L2AU3
    AE menu items defect
    L2AU3
      My AE Help menu including Scripting Help, Expressions Reference, Animation Presets, Keyboard Shortcuts have no functionality. It installed this way on Vista/PC from Adobe disk.  (The Help menus in the rest of the suite (PS, AI, FL, PP) are okay if I remember correctly. The help menu problem is in After Effects CS4.) I am working in AE more and I would like the help features.Can anyone tell me how to fix this?
        • 1. Re: AE menu items defect
          Probably it got never installed correctly, you have a lnagugae conflict or moved the files. Check whether this folder exists and if you have ful laccess to it: C:\Program Files (x86)\Common Files\Adobe\Help\en_US\AfterEffects\9.0, assuming you want the English help files. If you run AE in anotehr language, naturally it will look for a different language folder such as de_DE for German or fr_FR for French. In any case, you can look up the help on the web any time or manually open the files in a browser...
          Mylenium
          • 2. Re: AE menu items defect
            L2AU3 Level 1
            Per your instructions I found that AE is not in the en_US folder. I am interested in correcting this because the menu will save much time over the online option. I have been struggling using "help" without the help menu shortcuts. Where can I locate the needed file and how do I install it to AE?
            Date: Thu, 19 May 2011 08:28:45 -0600
            To: corpora_striata@hotmail.com
            Subject: AE menu items defect
            Mylenium
            • 3. Re: AE menu items defect
              If they ended up in anotehr language folder, you can simply copy them over to the correct one. Maybe you are simply a victim of a problem in the Internaional English installer, where files end up in the en_GB sub-folder...
              Mylenium
              • 4. Re: AE menu items defect
                L2AU3 Level 1
                What is the name of the files I am looking for that has the English Help? I do not have en_GB subfolder so it isn't there and I didn't see anything that would represent the help file in any of the other subfolders. I will look through the disk to find the files but I need to be sure of the name.
                Date: Thu, 19 May 2011 08:57:30 -0600
                Mylenium
                • 5. Re: AE menu items defect
                  L2AU3 Level 1
                  Mylenium,
                  I'm still on this problem. I snipped my windows so you can see the problem via the attachments to this email. Can you can advise me how to move the After Effects en_US Language file to the Adobe Help? I'm looking at the contents on the disc and I don't know how to address it.
                  Laurrie
                  Mylenium
                  • 6. Re: AE menu items defect
                    Todd_Kopriva Level 8
                    By the way, you don't need to use the Help menu to get to the Help document. It's available on the Web in both HTML format and PDF.
                    • 7. Re: AE menu items defect
                      L2AU3 Level 1
                      I would like the Help menu as a shortcut alternative. I have CS4 so the CS5 link implies more in its answers that what my software is capable of.  I would like to get this Help Menu issue resolved. I often have many windows open and I have a favorites bar full of links so it is very cumbersome to go outside of AE for the Help Menu. I want the Help Menu shortcuts and the F1 key. That is what I paid for! Any suggestions on how pull the file off the disk and manually install it?  I have reinstalled AE and it didn't resolve the problem.
                      Date: Thu, 19 May 2011 12:10:47 -0600
                      By the way, you don't need to use the Help menu to get to the Help document. It's http://blogs.adobe.com/premiereprotraining/2010/08/help-documents-for-creative-suite-5-pdf -and-html.html.
                      • 8. Re: AE menu items defect
                        The people who can help you with failures with the Help software are not here on the After Effects forum. They're on this forum for the Help software itself:
                        http://forums.adobe.com/community/creativesuites/communityhelp?view=discussions
                        • 9. Re: AE menu items defect
                          L2AU3 Level 1
                          The link that you gave me is for the online Community Help application protocol. I see nothing there that would refer to After Effects software. My Help Menu issue concerns missing or misplaced files in the After Effects CS4 Help Menu.
                          Date: Thu, 19 May 2011 13:01:43 -0600
