1. Re: Telephoto lense effect?
Semaphoric May 19, 2011 9:23 AM (in response to avpromedia)Content-aware scaling with the rectangle protected, maybe?
2. Re: Telephoto lense effect?
Noel Carboni May 19, 2011 9:31 AM (in response to avpromedia)There's no one transform that's going to do this for you, but depending on your photo could you just make a mask that allows you to "see through" the door, then scale up a second copy of the image so that it's much larger (thus making the depth from the door to the subjects seem compressed, as a telephoto would). Something like this could be repeated on several planes if the subject material warrants it.
Content Aware Scaling is a neat idea, Semaphoric. That would be fun to experiment with.
-Noel
3. Re: Telephoto lense effect?
Semaphoric May 20, 2011 5:44 AM (in response to avpromedia)One thing you'd have to watch out for is, if the technique you use is dependant on the distance from the center of the image, any vertical subject might look like it was bent or leaning in some direction. You'd have to make sure that the whole subject ws scaled by the same factor as where it meets the ground plane.
