7 Replies Latest reply on May 31, 2011 11:57 AM by Gene Godsey
    onChange method
    Gene Godsey Level 1
      I know this is a JavaScript issue but I will go ahead and ask this anyway.
      I need a javascript function that will allow my textbox to enable the submit button in the form when the textbox becomes populated with text.
      Thanks in Advance.....
        • 1. Re: onChange method
          Dan Bracuk Level 5
          Your google search string is "javascript show hide"
          • 2. Re: onChange method
            Gene Godsey Level 1
            That is one idea BUT.............
            I need to have a method that the trigger an event via a textbox insertion/callback that will enable the submit button w/o having to use the onKeyUp method. The actual text field is hidden and the field needs to enable the disabled submit button.
            I.E.:
            <script language="javascript" type="text/javascript">
            function SetButtonStatus(sender, target) {
                if ( sender.value.length >= 1 )
                document.getElementById(target).disabled = false;
                 else
                document.getElementById(target).disabled = true;
            <script>
            <asp:TextBox ID="txtText" runat="server" onkeyup="SetButtonStatus(this, 'btnButton')">asp:TextBox>
            <asp:Button ID="btnButton" runat="server" Text="Button" Enabled="false" />
            Sorry it's in Dot.Net but you get the idea.
            • 3. Re: onChange method
              Dan Bracuk Level 5
              You want to use the value of a hidden field to enable/disable the submit button?  Is there user input involved anywhere?
              • 4. Re: onChange method
                Gene Godsey Level 1
                There is a callback from another javascript method that is placing data into that field.
                There are no key strokes involved so the keyUp() method is not going to work.
                • 5. Re: onChange method
                  Dan Bracuk Level 5
                  Then perhaps the answer is to incorporate the enable/disable logic in that first javascript function.
                  • 6. Re: onChange method
                    gitobu
                    Dan,
                    I do not know whether you have an aswer yet but if your intention is
                    to stop a form from submitting when the text box is blank you may create a function that
                    ensures that the field is not blank, and have the function called on submit.
                    <script type="text/javascript" language="javascript">
                    function ensureNotBlank (){
                    if (document.formname.fieldname.value == ""){
                      alert('Please enter a whaterver');
                      return false;
                    </script>
                    On your submit button:
                    <input type submit" value="Send data" onClick="return ensureNotBlank()">
                    If the textbox is blank you have the alert and the form is not submitted. If it is populated the form submits.
                    Allan
                    • 7. Re: onChange method
                      Gene Godsey Level 1
                      This is a possible solution but what I was really looking for was to keep the submit button disabled until the textbox was populated with content.
