Flex List with data-grid issue any body can help me ......i added the full code below
senthil s May 20, 2011 3:33 AMFlex List with data-grid issue any body can help me ......i added the full code below
Exactly wat i need is
1.if i click the open button want to visible all datagrid ,its working perfectly.
2.if i click the close button want to close all data grid ,its working perfectly.
3. if i click a particular list means want to visible particular datagrid..some times working good but some times not visible ...
4.if i click the list if datagrid already open means want to close .some times creates extra space below the datagrid........
if u cont get clearly please copy the below code and check it.......and give the right solution for this problem.......
<s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx" width="100%" height="100%" >
<fx:Declarations>
</fx:Declarations>
<fx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
[Bindable]
public var ArrUserList:ArrayCollection;
[Bindable]
public var listDB:ArrayCollection = new ArrayCollection([ {label: "2011", data:"jan",day:"saturday",date:"1-4-11"},
{label: "2011", data:"jan",day:"monday",date:"13-4-11"}, {label: "2013", data:"jan",day:"monday",date:"1-5-11"}, {label: "2013", data:"jan",day:"wednesday",date:"14-5-11"}, {label: "2015", data:"jan",day:"tuesday",date:"11-5-11"}, {label: "2015" ,data:"jan",day:"friday",date:"1-6-11"} ]);
public var loc_first_last_name:String;
function Load():void
ArrUserList=Find_Duplicate(listDB);
for(var i:int=0; i<ArrUserList.length; i++)
ArrUserList[i].click=0;
Lst_userlist.dataProvider=ArrUserList;
Lst_userlist.rowCount=ArrUserList.length;
function Clink_lnk_open():void
if(lnk_open.label=="Open")
ArrUserList[i].click=1;
lnk_open.label="Close";
ArrUserList.refresh();
Lst_userlist.validateNow();
Lst_userlist.rowCount = ArrUserList.length ;
else
lnk_open.label="Open";
function Click_UserName1(event:MouseEvent,data:Object):void
loc_first_last_name=event.currentTarget.text;
var str:String;
str=ArrUserList[i].label;
if(loc_first_last_name==str)
if(ArrUserList[i].click == 0)
else
public function Find_Duplicate(test_arr:ArrayCollection):ArrayCollection
var res_arr:ArrayCollection=new ArrayCollection();
var flag:Boolean;
for(var i:int=0;i<test_arr.length;i++)
var j:int=0
flag=false;
for(;j<res_arr.length;j++)
if(res_arr[j].label==test_arr[i].label)
res_arr[j].dataCollection.addItem(test_arr[i]);
flag=true;
break;
if(!flag)
var myItem:Object = new Object() ;
myItem.label=test_arr[i].label;
myItem.dataCollection=new ArrayCollection();
myItem.dataCollection.addItem(test_arr[i]);
res_arr.addItem(myItem) ;
return res_arr;
</fx:Script>
<s:Scroller id="id_scroller" width="100%" height="100%">
<s:VGroup id="id_Vgroup" paddingLeft="50" paddingTop="10" paddingBottom="10" width="100%" height="100%" >
<mx:VBox width="850" paddingLeft="0" paddingTop="1" color="black" backgroundColor="#FFFFFF">
<mx:HBox width="850" left="50" paddingBottom="3" paddingLeft="5" backgroundColor="#6D6C6C" paddingTop="3" color="#FFFFFF" >
<mx:LinkButton id="lnk_open" label="Open" textDecoration="underline" click="Clink_lnk_open();"/>
<mx:Button id="load_btn" label="Load" click="Load()"/>
</mx:HBox>
<mx:VBox id="Vbox_main" width="850" horizontalScrollPolicy="off" verticalScrollPolicy="off" >
<mx:List variableRowHeight="true" width="850" id="Lst_userlist" paddingTop="-3" verticalScrollPolicy="off" horizontalScrollPolicy="off"
buttonMode="true" >
<mx:itemRenderer>
<fx:Component>
<mx:VBox paddingTop="-5" horizontalScrollPolicy="off" verticalScrollPolicy="off" >
<fx:Script>
<![CDATA[
override public function set data(value:Object):void
super.data = value;
Membership_Grid.dataProvider=data.dataCollection;
Membership_Grid.rowCount=data.dataCollection.length;
lbl_userhead.text=data.label;
lbl_userhead1.text=data.dataCollection.length+" Datas";
if(data.click==1)
Vbox_main.visible=true;
Vbox_main.includeInLayout=true;
else
Vbox_main.visible=false;
Vbox_main.includeInLayout=false;
Membership_Grid.validateNow() ;
</fx:Script>
<mx:HBox id="vbox_grid" horizontalScrollPolicy="off" height="25" verticalScrollPolicy="off" width="850" paddingLeft="10" paddingTop="5" backgroundColor="#6D6C6C" color="#FFFFFF">
<s:Label id="lbl_userhead" click="outerDocument.Click_UserName1(event,data)" buttonMode="true" width="250" paddingTop="3" />
<s:Label id="lbl_userhead1" buttonMode="true" width="548" paddingTop="3" />
</mx:HBox>
<mx:VBox id="Vbox_main" width="850" horizontalScrollPolicy="off" verticalScrollPolicy="off" visible="false" includeInLayout="false" >
<mx:DataGrid id="Membership_Grid" alternatingItemColors="[#DCDCDC,#F8F8FF]" paddingLeft="5" horizontalScrollPolicy="off" color="black"
horizontalGridLines="false" verticalScrollPolicy="auto" verticalGridLines="false" rowHeight="25" width="850" borderSkin="{null}"
borderVisible="false" >
<mx:columns>
<mx:DataGridColumn width="150" headerText="Year" dataField="label"/>
<mx:DataGridColumn width="150" headerText="Month" dataField="data"/>
<mx:DataGridColumn width="150" headerText="Day" dataField="day" />
<mx:DataGridColumn width="150" headerText="Date" dataField="date"/>
</mx:columns>
</mx:DataGrid>
</mx:VBox>
</mx:VBox>
</fx:Component>
</mx:itemRenderer>
</mx:List>
</mx:VBox>
</mx:VBox>
</s:VGroup>
</s:Scroller>
</s:Group>
