2 Replies Latest reply on May 24, 2011 8:40 AM by Jonathan Braun
    Flash Builder 4.5 - Flex (source code automatically changed after existing project import)
    Jonathan Braun
      Hi all!
      Til yesterday, i was using FB v4.0 and it was perfectly working.
      But now I'm under 4.5 and i have problem when importing my existing projects.
      Now let me introduce the matter:
      The entire project solution is located on my Desktop.
      So, to import this, i go in FB in File>Import Project
      Then i select "Project Repository" option and "Browse" button, then select the project on Desktop...
      So.... import complete and SEEM TO BE successful
      Unfortunately, from the IDE, when i double click on each source files, the code inside is not the expected one.
      In fact, it looks as an older version of my code.
      Then, i exit totally FB4.5...
      ... and open my source files with a simple text editor, i can see that the original code (before import) has been changed by FB4.5...
      So, why???
      for example, this original code:
       * This is a generated class and is not intended for modification.  To customize behavior
       * of this service wrapper you may modify the generated sub-class of this class - WS_rq_login.as.
      package services.ws_rq_login
      import com.adobe.fiber.core.model_internal;
      import com.adobe.fiber.services.wrapper.WebServiceWrapper;
      import com.adobe.serializers.utility.TypeUtility;
      import mx.rpc.AbstractOperation;
      import mx.rpc.AsyncToken;
      import mx.rpc.soap.mxml.Operation;
      import mx.rpc.soap.mxml.WebService;
      [ExcludeClass]
      internal class _Super_WS_rq_login extends com.adobe.fiber.services.wrapper.WebServiceWrapper
          // Constructor
          public function _Super_WS_rq_login()
              // initialize service control
              _serviceControl = new mx.rpc.soap.mxml.WebService();
              var operations:Object = new Object();
              var operation:mx.rpc.soap.mxml.Operation;
              operation = new mx.rpc.soap.mxml.Operation(null, "WS_rq_login");
               operation.resultType = Object;
              operations["WS_rq_login"] = operation;
              _serviceControl.operations = operations;
              try
                  _serviceControl.convertResultHandler = com.adobe.serializers.utility.TypeUtility.convertResultHandler;
              catch (e: Error)
              { /* Flex 3.4 and earlier does not support the convertResultHandler functionality. */ }
              preInitializeService();
              model_internal::initialize();
          //init initialization routine here, child class to override
          protected function preInitializeService():void
              _serviceControl.service = "A_WebService";
              _serviceControl.port = "A_WebServicePort";
              wsdl = Config.LIEN_WS_RQ_LOGIN+"/4dwsdl";
              model_internal::loadWSDLIfNecessary();
            * This method is a generated wrapper used to call the 'WS_rq_login' operation. It returns an mx.rpc.AsyncToken whose
            * result property will be populated with the result of the operation when the server response is received.
            * To use this result from MXML code, define a CallResponder component and assign its token property to this method's return value.
            * You can then bind to CallResponder.lastResult or listen for the CallResponder.result or fault events.
            * @see mx.rpc.AsyncToken
            * @see mx.rpc.CallResponder
            * @return an mx.rpc.AsyncToken whose result property will be populated with the result of the operation when the server response is received.
          public function WS_rq_login(e_login:String, e_password:String, e_keyCode:String, e_forceRegenKey:Boolean) : mx.rpc.AsyncToken
              var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("WS_rq_login");
                var _internal_token:mx.rpc.AsyncToken = _internal_operation.send(e_login,e_password,e_keyCode,e_forceRegenKey) ;
              return _internal_token;
      becomes this:
      [ExcludeClass]
          // Constructor
              try
              catch (e: Error)
                wsdl = "http://ids.ice/4dwsdl";
      Thanks for your help
      Jonathan
