4 Replies Latest reply on May 31, 2011 6:29 AM by BapediBoupi
    SOAP Request timeout
    BapediBoupi
      Hi everyone,
      I've made a LC short-lived process, that I'll call using SOAP (as a WebService) :
      It's a simple process which accepts a username to look for (string) as input and returns two strings (user ID and username found).
      I've created another application with a form in which i linked this corresponding wsdl file.
      My problem is when I try to invoke the service (using a button in my form), I got an error approximately 30 seconds after, because the request timed out.
      Is there a way to extend the timeout for a soap request inside a pdf form ?
      Kind regards,
      Thomas
        • 1. Re: SOAP Request timeout
          pguerett Level 6
          Are you using Reader or Acrobat when you make this call?
          Paul
          • 2. Re: SOAP Request timeout
            BapediBoupi Level 1
            I'm using Adobe Reader X inside the workspace.
            Any suggestions ?
            Regards,
            Thomas
            • 3. Re: SOAP Request timeout
              pguerett Level 6
              Did you reader extend the form to allow web service calls? This must be done through LiveCycle Reader Extensions Server and cannot
              be done through Acrobat.
              Paul
              • 4. Re: SOAP Request timeout
                BapediBoupi Level 1
                Yes the form is reader extended to allow web services call ... But i've found a "solution"
                I changed my webservice to make a direct query in the LiveCycle database, this way it is faster.
                Then i made the call programatically in JavaScript. Now everything's working.
                I've got a question though :
                When I use the findUser operation, it took like 90 seconds to retrieve the corresponding users as an xml list.
                When I use a direct Query multiple row (I wrote the sql request myself), it took like 5 secondes to retrieve the corresponding users as an xml list (with the same informations)
                Why is the findUser operation so slow ? What does it do behind ?
                Regards,
                Thomas
