1 Reply Latest reply on Oct 18, 2011 11:50 PM by prasaxen
    Using ExportPDF to convert to HTML
    sphatt
      I keep on receiving this error when trying to convert to HTML, but I've got the suggested environment variable defined.
      Error Code:80023
      Error Message:  ALC-PDG-080-023-Acrobat_PATH environment variable either not set or is invalid.  Please set this variable to point to Acrobat.exe in Acrobat version 9 with  update 1. Acrobat_PATH should be set to <Acrobat_Home>\Acrobat  9.0\Acrobat\Acrobat.exe. Here <Acrobat_Home> is the parent folder where  the Acrobat is installed.
      P.S.  I can use ExportPDF to convert to image format just fine (tif,jpeg,etc.)  I also can open acrobat and convert a pdf to HTML without any problem on the server as well.
        • 1. Re: Using ExportPDF to convert to HTML
          prasaxen Level 1
          I have designed a workflow in Workbench ES2 using export pdf operation and I am trying to convert pdf to doc.
          while trying to invoke this process  I am getting the same error :
          I have set the Acrobat_PATH system/user variable point to acrobat.exe but still i  am getting this error.
          Can  anyone help me out in this.
