9 Replies Latest reply on Feb 6, 2018 9:33 AM by Henry.Pineda
    CS5 Publishing to Android errors: can anyone help?
    helenthegreat_2011
      Hi I'm a novice android app developer and am trying to publish an apk file to test on my HTC desire phone. I have gone through all of the publish settings and can't see that I've done anything wrong. However, I keep getting the following errors. Has anyone seen this before? If so how do I fix it and publish my .apk file.
      An attribute or element contains an invalid value in the application descriptor file.
      error 105: application.id contains an invalid value
      application.id
      thanks
      Ok maybe this will help a bit. This is the contents of the XML file created when I publish from Flash CS5. I can't see any errors but then again I'm not sure what exactly I'm looking at.
      <?xml version="1.0" encoding="utf-8" standalone="yes"?>
      <application xmlns="http://ns.adobe.com/air/application/2.5">
          <id>le_can_count_2</id>
          <versionNumber>1.0.0</versionNumber>
          <filename>le_can_count_2</filename>
          <description></description>
          <!-- To localize the description, use the following format for the description element.
          <description>
              <text xml:lang="en">English App description goes here</text>
              <text xml:lang="fr">French App description goes here</text>
              <text xml:lang="ja">Japanese App description goes here</text>
          </description>
          <name>le_can_count_2</name>
          <!-- To localize the name, use the following format for the name element.
          <name>
              <text xml:lang="en">English App name goes here</text>
              <text xml:lang="fr">French App name goes here</text>
              <text xml:lang="ja">Japanese App name goes here</text>
          </name>
          <copyright></copyright>
          <initialWindow>
              <content>le_can_count_2.swf</content>
              <systemChrome>standard</systemChrome>
              <transparent>false</transparent>
              <visible>true</visible>
              <fullScreen>true</fullScreen>
              <autoOrients>true</autoOrients>
              <aspectRatio>portrait</aspectRatio>
              <renderMode>cpu</renderMode>
          </initialWindow>
          <customUpdateUI>false</customUpdateUI>
          <allowBrowserInvocation>false</allowBrowserInvocation>
          <icon>
              <image36x36>36x36.png</image36x36>
              <image48x48>48x48.png</image48x48>
              <image72x72>72x72.png</image72x72>
          </icon>
          <android>
              <!-- <manifestAdditions><![CDATA[<manifest></manifest>]]></manifestAdditions> -->
      <uses-permission android:name="android.permission.INTERNET"/></manifest>
      ]]></manifestAdditions></android>
          <versionLabel></versionLabel>
      </application>
