2 Replies Latest reply on Mar 26, 2007 1:10 AM by Newsgroup_User
    <br/> is interpreted as </li><li>  in TextField.htmlText
    Level 7
      I have a text filed created like this:
      createTextField();
      .type = "dynamic";
      .multiline=true;
      .html = true;
      .htmlText = myText;
      myText = "<ul><li> blah-blah blah-blah </li></ul>";
      The problem is that the text is too long and I inserted <br/> in the middle
      like that:
      myText = "<ul><li> blah-blah <br/> blah-blah </li></ul>";
      which works fine in HTML, but in FLASH this creats another list item as if
      it was
      myText = "<ul><li> blah-blah </li><li> blah-blah </li></ul>";
      What is the problem and how do I get round it
        • 1. Re:  &lt;br/&gt; is interpreted as &lt;/li&gt;&lt;li&gt;  in TextField.htmlText
          Level 7
          aa,
          The UL tag is not supported in Flash, so you may omit it. (Search the
          phrase "supported HTML tags" in the documentation to see the full subset of
          supported tags -- it's a limited subset.)
          > <br/> in the middle like that:
          > another list item
          I don't recall that I've ever experienced what you describe, but it
          doesn't particularly surprise me. HTML formatting can be a very useful
          thing in Flash -- but you have to fully appreciate how limited the support
          is. I would do a bit of isolated experimentation in a new FLA to confirm
          what you've discovered, and if that's truly what a BR tag does inside LI,
          then you'll know to avoid that situation.
          You may have to use the IMG tag to provide a "bullet" of your own and
          follow it with content inside a P tag. Look into the StyleSheet class in
          the ActionScript 2.0 Language Reference to see what your options are for
          CSS. That, and/or the TEXTFORMAT tag will will allow you manipulate margins
          in a way that lets you simulate bulleted lists.
          David Stiller
          Adobe Community Expert
          Dev blog, http://www.quip.net/blog/
          "Luck is the residue of good design."
