2 Replies Latest reply on May 28, 2011 9:19 AM by Shongrunden
    Decorator not changing when you click on listitem
    HeylenThibault
      Dear,
      I'm developing a mobile application for my thesis and I was working with flash builder burrito. I now installed the new SDK and flashbuilder 4.5.
      I changed my code a little bit so it would work with the new SDK.
      But there's one problem I can't solve.
      I have a list with objects in it. When the element is not checked you can see a gray V, when you click on it it should become a green V. So the user can see wich one is checked and wich not. Here for I use a list with an itemrenderer.
      The problem is when he loads the page he can set the decorator correctly. But when you click on a listitem he doesn't change the decorator.
      I've allready tried to debug , and the debugger is going to the itemrenderer and setting the decorator but de decorator doesn't change in my list.
      I made a small example to show:
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:s="library://ns.adobe.com/flex/spark" title="Home"
                initialize="init()">
           <fx:Script>
                <![CDATA[
                     import mx.collections.ArrayCollection;
                     [Bindable]
                     private var m_list:ArrayCollection = new ArrayCollection();
                     private function init():void
                               for(var i:int = 0 ; i<5 ; i++)
                                    var test:SelectableItem = new SelectableItem("Item"+i);
                                    m_list.addItem(test);
                     protected function list1_clickHandler(event:MouseEvent):void
                          SelectableItem(m_list.getItemAt(listID.selectedIndex)).toggleSelection();
           </fx:Script>
           <s:List id="listID"
                     x="0" y="99" width="480" height="596"
                     dataProvider="{m_list}"
                     itemRenderer="views.ListItemRenderer"
                     click="list1_clickHandler(event)"/>
      </s:View>
      This is my class:
      package views
           public class SelectableItem
                private var m_name:String;
                private var m_selected:Boolean;
                public function SelectableItem(name:String,selected:Boolean = false)
                     m_name = name;
                     m_selected = selected;
                public function get name():String
                     return m_name;
                public function set name(value:String):void
                     m_name = value;
                [Bindable]
                public function get selected():Boolean
                     return m_selected;
                public function set selected(value:Boolean):void
                     m_selected = value;
                public function toggleSelection():void
                     selected = !selected;
      and here is my itemrenderer:
      <s:IconItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                               xmlns:s="library://ns.adobe.com/flex/spark"  iconWidth="64" iconHeight="64"
                               labelFunction="itemLabelFunction">
           <fx:Script>
                <![CDATA[
                     [Embed(source="checked.png")]
                     public var checked:Class;
                     [Embed(source="unchecked.png")]
                     public var unchecked:Class;
                     override public function set data(value:Object):void
                          super.data = value;
                          if(value != null)
                               if(value.selected)
                                    decorator = checked;
                                    setStyle("color", "red");
                               else
                                    decorator = unchecked;
                                    setStyle("color", "black");
                     private function itemLabelFunction(item:Object):String
                          return item.name;
           </fx:Script>
      </s:IconItemRenderer>
      As you can see I also use setStyle and change the color when you click it. This is because that works. This is only temporary offcourse.
      And I think that's a strange thing that setStyle does work but setting the decorator to a new image doesn't.
      I hope my question was clear and that someone can help me.
      Thanks in advance.
      Kind regards,
      Thibault Heylen
