2 Replies Latest reply on May 24, 2011 4:37 AM by GordonEddey
    How do I script a 3-up master
    GordonEddey
      Hope you can help. I am trying to create a three page masterSpread in indesign cs3.
      To do this I have used the masterSpreads.jsx script provided by Adobe and then simply added another page, which seems logical to me, but it does not work.
      If I create masters using the two page option and then go into Master Options I can add the page manually.
      What I really want is to create a 3-up  external masterSpread and a 3-up internal masterSpread - with different global logos and backgrounds for the specfic pages.
      These will then wrap around a conventional 2-up inside section, which will have another masterSpread setting.
      I have included the code below for reference.
      I assume I need to change the master options to increase the number of pages, and have looked on my well-used Jongware reference but I cannot work it out.
      Please help.
      Regards,
      Gordon Eddey
      gordon.eddey@eddit.co.za
      HERE IS THE SCRIPT AS IT STANDS:
      //Set up the first master spread in a new document.
      myDocument = app.documents.add();
      //Set up the document.
      with (myDocument.viewPreferences)
                  {/*doc.viewPreferences*/
                                  horizontalMeasurementUnits = MeasurementUnits.MILLIMETERS
                                  ;  verticalMeasurementUnits = MeasurementUnits.MILLIMETERS
                                  ;  rulerOrigin = RulerOrigin.PAGE_ORIGIN
                                  ;  showRulers = true
      with(myDocument.documentPreferences)
          pageHeight = "297mm"
          ; pageWidth = "210mm"
          ; facingPages = true
          ; pageOrientation = PageOrientation.portrait
          ; pagesPerDocument = 3
      //Set the document's ruler origin to page origin. This is very important
      //--if you don't do this, getting objects to the correct position on the
      //page is much more difficult.
      with(myDocument.masterSpreads.item(0))
      //Set up the left page (verso).
          with(pages.item(0))
          //Add a simple footer with a section number and page number.
              with(textFrames.add())
                  geometricBounds = ["280", "15", "290", "200"]
                  insertionPoints.item(0).contents = SpecialCharacters.sectionMarker;
                  insertionPoints.item(0).contents = SpecialCharacters.emSpace;
                  insertionPoints.item(0).contents = SpecialCharacters.autoPageNumber;
                  paragraphs.item(0).justification = Justification.leftAlign;
      with(pages.item(1))
      with(pages.item(2))
        • 1. Re: How do I script a 3-up master
          milligramme Level 3
          Hi
          myDocument.documentPreferences.pagesPerDocument = 3;
          is not for MasterSpread, it's for PageObject.
          So masterSpread[0].pages[2] is not yet existed.
          You can fix your code simply rewrite line 58 and try.
          GordonEddey wrote:
          with(pages.item(2))
          to
          with(pages.add())
          thanks
          mg/
          • 2. Re: How do I script a 3-up master
            GordonEddey Level 1
            Hi Milligramme,
            Your solution worked instantly. Thanks very much.
            I was so busy trying to find a new .item, I never thought of the very logical .add in this case.
            I wonder: would it make sense to produce a new master, using the .add for each page, or does one always use the double page master as the parent?
            I really appreciate your help.
            Regards
            Gordon Eddey
