1 Reply Latest reply on May 26, 2011 8:39 AM by badgeteam
    Importing XML Response Files
    jrusling
      We have a form that is facilitating a submission to a server location as an XML file. Initially things were going well. Opening the response file would automatically load any new responses. Unfortunately after 50 or 60 responses were loaded the computer crashed and after recovering the response file only shows 33 responses so apparently the file was not saved correctly. Is there a way to manually import the XML responses into the response file?
        • 1. Re: Importing XML Response Files
          badgeteam
          I know that I Import the form's XML Data directly into my Pdf by doing the following -
          Open the Form - Click on Tools - Then on Forms - Got to More Form Options - then Manage Form Data - Import Data - From here you can navigate to where your XML is saved and Import the Data.
          This is the only way I know how to do this, but it works well for us.
          Hope it helps.
