What is in the Audition 3.0.1 bugfix?
SteveG(AudioMasters) May 23, 2011 2:25 PMChanges in Adobe Audition 3.0.1:
• Spectral tools no longer crash machines with more than four CPU cores.
• The Graphic Phase Shifter effect has been re-enabled.
• Performance while recording MIDI data has been improved.
• The Sequencer will now record MIDI data even if the panel is closed.
• Adobe Audition will now launch on Windows Vista® systems where the My Documents folder was moved from the default location.
• The application will now ignore Windows "Locale" settings to format decimal data in comma-delimited XML settings files.
• A Healing Brush crash issue has been addressed.
• Cross-fades are no longer incorrectly added to grouped clips when overlapped with non-grouped clips.
• Invalid cross-fades will no longer be added to the end of a previously trimmed clip after enabling or disabling looping.
• Invalid cross-fades for clips after enabling non-session tempo-based looping have been addressed.
• Dragging cross-faded clips onto the master track no longer creates two additional tracks and an error in the cross-fades.
• Inserting MIDI from the Files panel would cause the application to hang in Edit mode for an audio file whose sample rate didn't match the session.
• Several scenarios where cross-fade changes could corrupt a session were addressed.
• Closing a session without exiting the rewire app no longer causes Adobe Audition to save a blank session.
• Undo no longer becomes disabled after undoing the creation of unique copies of two cross-faded clips.
• Cross-faded clips no longer disappear after undoing move clips.
• Cancelling VST scan no longer causes Adobe Audition to become unstable.
• If a selection existed, a full session mixdown would only process MIDI data through the end of the selection.
• The Open MIDI dialog box was not completely modal and could cause a crash.
• MIDI Host had problems with some Spectrasonics VSTi instruments, where it wouldn't show the entire UI.
• CD burning would sometimes create a corrupted disk but still report a successful burn.
• Applying the Clip/Pop Eliminator no longer crashes the application.
• Crash recovery is now more reliable when using Auto-Save For Recovery.
• When the application detects the possible saving failure that causes a corrupted session, a warning dialog box now appears so users can retry the save.
• Transport controls are no longer disabled if a new session is opened without closing the existing session.
• Cross-fades will now retain their original shape when clips are moved and the session is reopened.
