4 Replies Latest reply: May 24, 2011 2:15 PM by [Jongware] RSS
    Find spot colors in document
    rigoliarts Community Member
      I'm preparing a document for print and when I go to package for output I get a message that there are a handful of spot colors in addition to the cmyk. Is there a way I can get InDesign to show me where in my document these spot colors are? (There are numerous placed graphics on numerous pages) I can't seem to find a "show" or "page number" for these colors. Also, if the little cmyk symbol shows up to the right of spot color in the swatched panel, am I okay as is to go to press?
        • 1. Re: Find spot colors in document
          P Spier CommunityMVP
          Perhaps the satest way to see where spot colors are in use is to open the Separations Preview panel and turnon separations, then click the eyeball next to CMYK. Anything left on the page is spot color. If you don't see a spot color listed in the panel, there is none in use.
          You asked if it was safe to go to print with spots, and the answer is it depends. Are you paying extra for spot colors? If not, from the swatches panel flyout menu choose Ink Manager, then check the box to Convert all Spots to Process, and for the best conversion to any known color space, check the box to use Lab values as well. Not sure waht you mean by seeing the CMYK symbol to the right of the swatch -- that means it isn't RGB, but there are two little icons there, and the one on the left will tell you if the color is spot, but neither one will tell you if it is being converted to process in the ink manager.
          • 2. Re: Find spot colors in document
            I used the Ink Manager to convert to process and also checked the lab color.
            • 3. Re: Find spot colors in document
              RodneyA Community Member
              I think you can do this in Acrobat as well, if you're exporting a PDF file. In Acrotbat, run the Advanced:Print Production:Preflight feature, Digital Printing (color), and look for errors; it should show you where they are.
              • 4. Re: Find spot colors in document
                [Jongware] Community Member
                There always is the Blatner Tools kit. Finding spot color is only one of its many functions
