3 Replies Latest reply on May 25, 2011 10:22 AM by The Feldkircher
    Server site php and As3 data
    adii08
      I am new in php coding. I want to get image data from php and also display in flash.
      I want to know... how to read and display imagejpeg( $imgData ); from php.
      I am able to get php data in flash through below method...
      /* AS3 */------------------
      var src:String = "pic.jpg";
      var width:String = "250";
      var height:String = "250";
      var urlReq:URLRequest = new URLRequest(src);
      var urlLoader:URLLoader = new URLLoader();
      var urlVar:URLVariable = new URLVariable();
      urlVar.src= src;
      urlReq.mehtod = URLRequestMethod.POST;
      urlReq.data = urlVar;
      urlLoader.load ( urlReq );
      urlLoader.addEventListener(Event.Complete, doneProcFnc)
      function doneProcFnc(ev:Event):void{
            trace ( "data access from php done" );
      /* PHP */
      $src = $_POST [ 'src' ];
      $wd = $_POST [ ' width' ];
      $ht = $_POST [ ' height' ];
      /*  this function will create one black color area for croping refence */
      $cropImg = imagecreatetruecolor ( cropImageWd, cropImageHt );
      /* this function will reproduce particular image required width and height without reducing the image quality */
      imagecopyresampled ( cropImage , sourceImage, destX , destY, sourX, sourY, ect... );
      imagejpeg( $imgData ) ;
      Now, here the problem comes. I don't know how to display that imagejpeg data into flash.
      I need help.
      Thanks.
        • 1. Re: Server site php and As3 data
          The Feldkircher Helper
          Hi
          In PHP simply echo your image back to flash:
          echo imagejpeg($imgData);
          In flash:
          For images it's best to use the Loader class rather than the URLLoader which is better suited to text or XML.
          I think you'll find the loader class far easier for your project.
          Hope it helps
          • 2. Re: Server site php and As3 data
            adii08 Newcomer
            Thanks.
            No.No.No. I am not loading image from folder.
            step1 : I m sending some image information to php (src , width , height)
            step2 : PHP code will take that information
            step3 : PHP code will crop that particular image (some calcution for quality)
            step4 : PHP code will generate some image data that is /* imagejpeg( $imgData ) */ and return back to flash
            step5 : Now the problem occur, how can i take that image data in flash or what form
            Possibilities :
            ? should i get image data as text format and it needs to be encoded (like jpeg encoder)
            ? i don't know i already try jpegencoder but i did not get anything
            urlVar.src= src;
                      trace ( "data access from php done" + ev.target );
                    // imagejpeg( $imgData )
            /* PHP */
            • 3. Re: Server site php and As3 data
              OK
              I am still not sure why your sending an image reference from flash to php and back again.
              Why not use the BitMap Class within flash to do your image sizing. It's far easier and more reliable.
              Google 'AS3 BitMap Class'
              Hope it helps
