2 Replies Latest reply on May 28, 2011 1:39 AM by Vishal Jaswal
    Robohelp keeps crashing
    dcavina1
      I installed RoboHelp 8.0.2.208 last year and have a couple of hundred topics and images (most are icon sized PNG and GIFs). Whenever I open a topic that contains images, RoboHelp will often crash and exit (no error messages). This is super annoying and I usually loose work .
      Any idea on what the problem is and what I can do to fix this? The images were captures using RoboScreenCapture or Photoshop and appear just fine normally. Usually a topic will open, but sometimes if just crashes the whole thing. Upgrading to version 9 is probably out of the question if it costs money as we just bought this and can't justify the expense.
      Thanks in advance,
      Dan
        • 1. Re: Robohelp keeps crashing
          Have you tried deleting the CPD file and reopening the project?
          Is the project on your hard disk?
          What version of Photoshop?
          I am not suggesting upgrading will fix it but be aware upgrading from 8 to 9 has been done at a special price so it would cost you less than you might be thinking. US$399 for RoboHelp on its own.
          @petergrainge
          • 2. Re: Robohelp keeps crashing
            Vishal Jaswal Level 2
            Hello
            Welcome to Adobe forums
            I was also facing the same issue.
            If you facing the crashing issue again and again, so here is a small workaround that you can try
            - Deactivate Robohelp (help>deactivate>
            - uninstall it completely
            - create a new admin account
            - install Robohelp in this new account
            - launch Robohelp and try to create a test project and observe that you still facing the same issue or not
            - if not, switch user and in your account launch Robohelp, then you are good to go
            If you still face the same isse , i suggest you to contact Adobe support.
            Hope it helps
            Vishal
