1 Reply Latest reply on May 24, 2011 12:42 PM by Filmzaddict
    PHP Connection in Flash Builder 4
    Gooner
      Hi
      Sorry if this is in the wrong place. I could see nowhere else to ask this question.
      I am very, very new to Flash Builder (in fact, I am following a tutorial on building a data-centric application using Flash catalyst CS5 and Flash Builder 4).
      The problem I am having is that I cannot seem to validate the data connection in Flash Builder 4.
      For my project, I click "Connect to Data/Service" then select PHP. I select Flex Server and change the "Application Server Type" to PHP.
      The page I then get asks for a Web Root and Root URL. This is where I'm having problems. No matter what I type in these boxes, when clicking the "Validate Configuration", I get the error of "Cannot access the web server".
      I have Apache and PHP installed on this Windows 7 64-bit machine.
      The Web root folder for my site is actaully held on my D drive, so web root reads.. "D:\Web Files\Site".
      The URL for this local site is http://site.local
      I can browse to http://site.local in my browser and all is well. My site shows. I can even see this fine in Flash Builder's Internal web browser.
      I have tried moving the web root folder inside the default apache root htdocs folder, but get the same problem. I have even changed the permissions on all folders to allow full control, but this doesn't help.
      I really am starting to tear my hair out now. Can someone please help me? Am I doing something obviously wrong?
      Many Thanks
        • 1. Re: PHP Connection in Flash Builder 4
          Filmzaddict Level 1
          Did you install apache / php / (optionally mysql) separately or in a bundle. I would suggest using xampp bundle, because it configures everything correctly along with installing a few helpful tools like phpmyadmin, etc. Great fast setup for testing purposes. Anyway... about the URL: I think the url you should be using is something like http://localhost/yourprojectfolder/...
          Presuming you have set up a project... and selected the option PHP at application server type you would then input (in my case, using the default xampp setup):
          Web root: C:\xampp\htdocs
          Root url: http://localhost
          Output folder: C:\xampp\htdocs\<projectname_here>-debug
          The url you d input in the browser to navigate to your project would then be: http://localhost/<projectname_here>-debug
          (no index.html at the end, provided your server is setup to serve this file automatically if it exists)
          Hope this helps!
