1 Reply Latest reply on May 24, 2011 3:11 AM by try67
    Does JavaScript do Touch up Text?
    hnp87255
      I'm a newbie in JavaScript. I have a requirement to find a string and replace with another string in a pdf file. I can use Touch up Text tool to update the text. However, as I need to do this "find and replace" action number of times, I thought of using JavaScript. I want to know if JavaScript can replace the text in a pdf file. Could you let me know of any other alternatives, if JavaScript can't touch up the text in PDF? One alternative I have in my mind is hiding the old text through annotation and overwriting with the new text, using JavaScript. I'm not sure, if it's possible, though. Can I get a small program to do one of these two alternatives?
      Thank you very much.
      Hemanth
        • 1. Re: Does JavaScript do Touch up Text?
          No, it can't replace the text. You need a plugin or an external application
          to do that.
          You can, however, remove the old text by redacting it, for example, or with
          a form field, and then place a text box on top with the new text, but if the
          length of the new text is different to that of the old text it might look a
          bit strange.
