Expand my Community achievements bar.
SOLVED
Saving an interactive PDF at the client
Avatar
Level 1
I have the LiveCycle Designer and have created an interactive form. I want some of my staff to be able to save the document on their computer, but they only have reader. Apparently this can be accomplished with the reader extensions, is this  part of x pro, or do I have to purchase it. Also there is another option to make the PDF Reader Enabled. I have looked in acrobet for the advanced tab and can't seem to find where to do this. Could someone please advise as to what I need to do and where I need to go to get this done. Itn is most frustrating. Thanks for your help.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
OK then ...under the file/save as/ Reader Extended PDF
Paul
View solution in original post
Avatar
Yes you can use Acrobat Pro to extend the PDF for Reader to save it locally.
Paul
Avatar
Level 1
Thanks Paul,  could you please let me know how I would go about doing this in acrobat Pro.
sean
Avatar
Which version of Pro do you have?
The operation is different between version X and previous versions.
Paul
Avatar
Level 1
Hi Paul,
I have just upgraded to version X.
Sean
Avatar
Correct answer by
Paul
Avatar
Level 1
Great, thanks for your help.
Sean
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
