2 Replies Latest reply on Jul 19, 2011 11:10 AM by kermy812
    [AS CS5] Tint of spot color to 100% tint of a different spot color
    kermy812
      Need some help writing a applescript - Still somewat new at this...
      I need to replace spot color with a different spot color.
      I have this in my script:
      try
      set myColorJ to color "CUSTOM_7538" of myDocument
      on error
      set myColorJ to make color with properties {name:"CUSTOM_7538", model:spot, color value:{29, 26, 29, 24}}
      end try
      try
      delete swatch "gray mix" replacing with swatch "CUSTOM_7538"
      end try
      However, in some places the are text or element that are tints. So a 75% tint of "gray mix", becomes a 75% tint of "CUST_7538".
      I want the 75% tint of "gray mix" to go to 100% "CUSTOM_7538".
      How can I get elements that are 75% tint of spot color to go to a 100% spot of a different color?
      Basically, anything that is 75% gray mix, need to be 100% CUSTOM_7538
        • 1. Re: [AS CS5] Tint of spot color to 100% tint of a different spot color
          kermy812 Level 1
          I figured out how to do text with this:
          tell application "Adobe InDesign CS5"
          set theDocument to active document
          set find frames preferences to nothing
          set change text preferences to nothing
          set fill color of find text preferences to swatch "gray mix" of theDocument
          set fill color of change text preferences to swatch "CUSTOM_7538" of theDocument
          set fill tint of change text preferences to 100
          tell theDocument
          change text
          end tell
          end tell
          How would I do objects/All Frames? I can't seem to get the syntax in my script. I thought it would be just changing the word "text" to "object" above, but its not. Any idea anyone? I can't seem to find any examples anywhere.
          • 2. Re: [AS CS5] Tint of spot color to 100% tint of a different spot color
            kermy812 Level 1
            Still havent't figured this out yet...
            I want to change objects that are a 75% "gray mix" to 100% "CUSTOM_7538"
            I thought I had it below, but it is changing everything that is a 75% tint to a 100% tint, whether it is "grey mix" or not.
            Any ideas what's wrong below?
            set myDocument to active document
            tell myDocument
            try
            set myColorI to color "CUSTOM_7538" of myDocument
            on error
            set myColorI to make color with properties {name:"CUSTOM_7538", model:spot, color value:{19.77, 24.49, 25.56, 41.59}}
            end try
            end tell
            set change object preferences to nothing
            set find object preferences to nothing
            set include footnotes of find change object options to true
            set include locked layers for find of find change object options to true
            set include hidden layers of find change object options to true
            set include locked stories for find of find change object options to true
            set include master pages of find change object options to true
            set object type of find change object options to all frames type
            set properties of find object preferences to {fill tint:75, fill color:"gray mix"}
            set properties of change object preferences to {name:myColorI, fill tint:100}
            tell myDocument
            change object
            end tell
            end tell
