1 Reply Latest reply on Jan 23, 2012 10:39 PM by DeepthiHL
    Automating PDF which is embedded within SAP Application
    Jaikrishna2011
      Hi all,
          I am facing the below mentioned problem.
      In this case, we need to do some navigations within the PDF like selecting values in the drop-down, checking checkbox etc.
      We tried installing Aptt plug-in in our system and recorded using the AcroQTP add-in but still the object gets recognized as one window object.
      I tried with different combinations of selecting addins like SAP-Web-VB-AcroQTP, AcroQTP-Web and Acro-QTP.
      In all the three cases, the PDF was recognized as one window object.
      The details of the application and QTP is,
      QTP - 9.5 version
      IE - 6.0 version
      Application Technology - SAP
      Pls let me know if there are any work arounds for this problem.
      Jayakrishna.S
        • 1. Re: Automating PDF which is embedded within SAP Application
          DeepthiHL
          Hi JaiKrishna,
          I have encountered same problem while working SAP application. We have installed the following on our systems:
          1. Acrobat 9.4
          2. QTP 10
          3. AcroQTP plugin
          The addin manager displays the plugin but while recording/spying the objects are identified as WinObject on the PDF which is invoked through SAP application.
          Could you or anyone from forum can help us out to solve this problem?
          Many Thanks,
          Deepthi
