1 3 4 5 6 7 Previous Next 258 Replies Latest reply on Nov 25, 2015 4:06 PM by fadhlul.rahman Go to original post
      • 200. Re: Media Encoder Stops Encoding with the New CS5.5
        jbiggs-nyc
        replaced the 2x1gb with 2x2gb.
        • 201. Re: Media Encoder Stops Encoding with the New CS5.5
          Paul_Duffey
          When the export dialog box comes up just make sure you press the [Export] button rather than the [Queue] button in order to render out of Premiere rather than Adobe Media Encoder. Basically this whole thread is based on AME locking up when it's Queued.
          • 202. Re: Media Encoder Stops Encoding with the New CS5.5
            jbiggs-nyc Level 1
            Thanks so much, this is HUGE help. I hate being a dummy.
            My video project involves five separate outputted MPG files - it's going to be show as five sync-ed videos. All five are very similar - one main track, with several additional tracks for the extra screens.
            After editing, I've been trying to line up all five versions on AME. I'll just do one at a time.
            • 203. Re: Media Encoder Stops Encoding with the New CS5.5
              Mark Mapes Adobe Employee
              Hi All,
              We recently isolated a repro case where encoding hangs with some regularity, and we'd like to know whether it covers the scenarios in which any of you have encountered hangs.
              • PPRO sequence contains a frame sequence of very high resolution stills (greater than 1920x1080. Our test project uses stills of 5184x3456.)
              • At least two or three such sequences are queued up in AME. It doesn't matter whether the first one is encoding when the subsequent ones are added or if you wait until they're all in the queue before starting to encode. However, the bug does not occur if you queue up only one job at a time, wait for it to complete, then add the next one.
              • And, consistent with most reports on this thread, GPU acceleration is enabled.
              In the above scenario, the first job encodes properly, but other jobs in the queue fail. Failure can take two forms:
              1. AME hangs indefinitely on the last frame before the super-HD frame sequence; if that frame sequence is at the very beginning of the sequence, then it hangs before you see any frame in the preview thumbnail.
              2. Encoding proceeds past that point, but the resulting video repeats the last frame before the super-HD content.
              This failure case is consistent with reports in this thread that a given job might work one time but fail the next. If, that is, the instance that fails was queued up right behind another such job.
              Two workarounds: wait until Job X is done before exporting Job Y; or go ahead and export Job Y but set its status to Skip in AME through the Edit menu or the context menu.
              This case is not consistent with reports that AME hangs at different points in the job, unless of course you're talking about either different sequences with the super-HD frame sequence at different positions, or a given sequence exported with different Work Area range or In/Out points.
              Please report whether this repro case fits your experience or not. We're very eager to know if we've nailed at least one of the scenarios that's been plaguing some of you.
              • 204. Re: Media Encoder Stops Encoding with the New CS5.5
                Paul_Duffey Level 1
                The times with my renders the only still layers I had was PSD layers the size of the screen (1920x1080), and it would hang in AME in the middle of encoding sequences, not at the end.
                • 205. Re: Media Encoder Stops Encoding with the New CS5.5
                  Thanks, Paul.
                  Just to clarify, I'm not referring to the hang occurring at the end of the sequence but on the last frame of regular SD or HD content before the super-HD content. If your sequences do not contain super-HD content, then the repro case we've isolated does not apply.
                  • 206. Re: Media Encoder Stops Encoding with the New CS5.5
                    BigArmDigital
                    Mark, this is EXACTLY what's going on in my case!
                    In my case I was queing up duplicates of the exact same sequence (titles, with the same background images but different PNG text tracks) and AME would run two sequences just fine and choke on the third sequence every single time. I had 16 different variations and no matter which I started with it would lock up at the start of the third sequence of the queue.
                    These sequences are 14 seconds long, 1920x1080p, but I was using a moving background track that was a 2324x1307 JPG file.
                    Turning off MPE and they queued up just fine (but oh so slow!).
                    Replacing the 2324x1307 JPG background image with the same (still moving) image at 1920x1080 and the queue worked just fine!
                    (of course there is a slight quality difference because I had a slight scale/zoom-in on the background image, but changing that image to a 1920x1080 image and no issues at all!).
                    If you need my system specs, please let me know. I've had this problem ongoing for six months but never tracked it down because it didn't always happen. I just got in the habit of only queing two sequences at a time.
                    In my case it is definitely the use of a scaling JPG that was larger than 1920x1080 that is causing the freeze.
                    • 207. Re: Media Encoder Stops Encoding with the New CS5.5
                      DirtyLowPull
                      my AME failures of duplicated sequences almost always contained
                      subsequences of still frames, but they were always no larger than 1920x1080
                      - a previous version of PPro would fail to encode larger images so we built
                      a resize to a max of 1920x1080 prior to import into our workflow and on 5.5
                      we stil do that.  Still AME would lock up randomly - on first or nth
                      original queued export - or later on while on one of the duplicated items
                      in AME - the duplicated are nearly always made in groups - queue a few
                      different prproj's to AME, then group duplicate all in the queue a few
                      times switching format and preset - I expect it to fail at some point with
                      MPE on.
                      • 208. Re: Media Encoder Stops Encoding with the New CS5.5
                        PeterLaJolla Level 1
                        I just want to report that I am also experiencing random, intermittent freezing issues when exporting a sequence to queue up in AME CS5.5. I initially had CUDA GPU acceleration turned on.  I've been trying to encode for the last three days. More than half of my files have successfully encoded. However, lately, I've noticed that the freezing has become more frequent, to the point that I'm tired of restarting the queue and getting fed up. I will now try encoding the remainder of my sequences with GPU acceleration turned off. I hope that works.
                        FYI, here's my info when I was trying to encode with GPU acceleration on:
                        Video recording device: Canon HV20
                        Video recording mode: HDV 1080/60i (1920x1080)
                        Audio recoding mode: 2 channel, 384kbps, 48 kHz
                        Video capture software: HDVSplit 0.77 beta
                        Video clip captured files: AVCHD Video, m2t files
                        Sequence info: 29.97 fps, 1920x1080, 48khz stero,
                        Sequence lengths: between 14 and 37 mins
                        Sequence video layers: only one (imported video clips)
                        Sequence effects: Cross fade only between clips, no other effects or filters
                        Export settings:
                           Multiplexer: MP4, iPod compatibilty
                           NTSC: 1280x720, 29.97 fps, de-interlaced
                           AAC: 64 kbps, 48Hz, Stero
                           VBR: 2Pass, Target 5.00, Max 7.00 Mbps
                           Use maximum render quality checked, Use Frame Blending checked
                           Filters: none
                        CPU temperature: about 50.0 degs C
                        GPU temperature: about 51.0 - 53.0 degs C
                        Software: Adobe Premiere Pro Version 5.5.2
                        Software: Adobe Media Encoder Version 5.5.1.12 (64-bit)
                        System OS: Windows 7 Ultimate SP1, 64-bit
                        System Processor: : Intel Core i7-3930K CPU @ 3.2Ghz
                        Installed RAM: 16.0 GB (Corsair CMT16GX3M4X2133C9 DDR3 PC3-17066 2133MHz)
                        Graphics Card: EVGA GeForce GTX 580 3072 MB GDDR5
                        Graphics Driver: Version 296.10, (Graphics clock 772 MHz, Processor clock 1544 Mhz)
                        Graphics BIOS version: 70.10.48.00.82
                        Motherboard: Asus P9X79 Deluxe
                        I hope you guys are able to find the problem. The whole reason why I bought the GTX 580 was for the CUDA acceleration, and now its worthless.
                        --Peter
                        • 209. Re: Media Encoder Stops Encoding with the New CS5.5
                          Paul_Duffey Level 1
                          For this one I'd try a couple drivers back on the card. The listed installed driver on my EVGA GTX 570 is 8.17.12.8026, but I know I downloaded the driver form EVGA's site around 5 months ago, so it's not at new as the latest one you posted which is a 2012. If you try a couple previous versions and that doesnt work, then I'd try to render directly out of premiere rather than queuing in the adobe media encoder. That's worked for a lot of people and with you just haveing a couple lengthy clips rather than lots of short clips, that might be the best solution for you anyway.
                          • 210. Re: Media Encoder Stops Encoding with the New CS5.5
                            Hi, Paul.
                            Thanks for the tips. I did as you suggested and just ran the render manually for each sequence out of Premiere, rather than queuing up in AME. I did this for five sequences without any problems, with GPU acceleration turned on.
                            I then turned GPU acceleration off and ran the remaining four sequences by queuing up in AME. I let the queue render overnight. They all rendered without problems.
                            The GPU acceleration made rendering dramatically faster. A clip which would take about 2 hours 20 mins to render with GPU acceleration off took about 12 mins to render with GPU acceleration on.
                            I did not backdate the graphics card driver.
                            • 211. Re: Media Encoder Stops Encoding with the New CS5.5
                              Paul_Duffey Level 1
                              Glad that worked atleast,. I bet if you tried some backdated drivers for your video card that might work too. If you do try let us know the results.
                              • 212. Re: Media Encoder Stops Encoding with the New CS5.5
                                BigRedFish
                                This had been plaguing me for months. Down-sampling super HD stills in my project has resolved this issue for me.
                                I had several images (over 4k across) that I was using as slide overlays and AME would hang on exporting just one of these (not even multiple copies) using CUDA acceleration on my Dell Precision laptop with an Nvidia Quadro FX 3800M graphics card. I would also get Nvidia messages that my hardware wasn't good enough (Premiere Pro 5.5 would then crash) while I was editing these stills in the timeline - e.g. putting fade transitions onto them.
                                Changing the stills to be 1920 x 1080 last night has fixed both the export problem and the editing crashes and AME got to the end of the export no problem.
                                Hope that helps.
                                Kaleel
                                • 213. Re: Media Encoder Stops Encoding with the New CS5.5
                                  nreedus
                                  I installed addition memory (8G) hoping this would solve the problem of freezing during export from AME. Unfortunately the problem persists with no clear path for a solution. I switched to PP from FCP and I like the system a lot. But if I can't export my 90 minute doc it is useless. Anybody, help, please.
                                  • 214. Re: Media Encoder Stops Encoding with the New CS5.5
                                    h2ofun Level 1
                                    Have you tried exporting straight from PP?  I gave up on AME a long time ago.  All my exports from PP work just fine.
                                    • 215. Re: Media Encoder Stops Encoding with the New CS5.5
                                      BigRedFish Level 1
                                      Are you editing video with large stills in the project? I down-sized my oversized stills to 1080p and it works fine now.
                                      • 216. Re: Media Encoder Stops Encoding with the New CS5.5
                                        tjsCreative1 Level 1
                                        I've solved this problem for my system and it was easy.
                                        I'm embarrassed to admit that I was cheating the system using a non-approved EVGA GTX550Ti and editing the approved list from a posting I had found on the internet.  Most of the time, everything worked well and the Mercury Render Engine raced through stuff.  On the more complex projects or with big stills, Premiere might occasionally crash and then on a couple projects, Media Encoder would just stop at random and couldn't get through the project.
                                        This past week i had an issue on a fairly complex project and decided that the issue was costing me money, so i went out and bought a new EVGA GTX580 with 3 GB video ram.  The same project breezed through with no issues and as hard as we have tried, we can't even make problems any more.
                                        I've learned that the Adobe and Nvidia experts may still be the real experts out there and I should just listen to them.  I paid a lot more in lost time and problems than I would have if I'd have just bought the right card in the first place.  I hope this same solution works for everyone.
                                        • 217. Re: Media Encoder Stops Encoding with the New CS5.5
                                          BigRedFish Level 1
                                          tjsCreative1 that's great and fantastic that it's resolved your problem.
                                          For my own setup, I have a desktop machine with a non-approved card in, but my laptop is where I do most editing and exporting because I do a lot of work at home. It's a Dell Precision M6500 with an Nvidia Quadro FX 3800M in it, which is on the approved list. However, AME was still exhibiting the same hanging issues on several projects (and during rendering operations) and the thing it was tripping over was the over-sized stills.
                                          • 218. Re: Media Encoder Stops Encoding with the New CS5.5
                                            Oversize stills have bothered Premiere Pro for me for years, way before Mercury.  Sorry to hear you have problem with approved card.
                                            I can say my Asus notebook i finally had to give up on.  Its Nvidia graphics card always overheated and reset, and Agearnotebooks said there was nothing wrong with it.  Now i use a Macbook Pro 17 with Windows 7.  I'm not impressed with MacOSx - it's like working with handcuffs for an old-fashioned Unix/Pc guy.  My next notebook will be a real PC again with Nvidia and i hope it works right.
                                            • 219. Re: Media Encoder Stops Encoding with the New CS5.5
                                              nreedus Level 1
                                              Exporting now from PP. 10 hours. Looking for post house to finish. Thanks.
                                              • 220. Re: Media Encoder Stops Encoding with the New CS5.5
                                                nreedus Level 1
                                                I do have quite a few stills but it doesn't freeze on a section with stills. Trying an export directly from PP now. I want to hand this baby over to someone else. Frustrated, tired.
                                                • 221. Re: Media Encoder Stops Encoding with the New CS5.5
                                                  zikade Level 2
                                                  By any chance - did you import it from FCP or did you create a fresh project? You may also try to disable CUDA for exporting - if enabled.
                                                  • 222. Re: Media Encoder Stops Encoding with the New CS5.5
                                                    BigArmDigital Level 1
                                                    @nreedus: When it's stills that cause my issues it doesn't freeze in the section with the stills, it just locks up at some point, usually not related to where the stills are in the sequence. Resizing the stills down to 1080 (or close) always fixes the issue for me. (I have 16GB of RAM and an approved nVidia card and still have issues if my stills are too big.)
                                                    Any beta testers of CS6 know if the new AME fixes the large stills issues?
                                                    • 223. Re: Media Encoder Stops Encoding with the New CS5.5
                                                      I'm not a beta tester, but I can report on the status of the hang involving sequences that contain very large still images. Unfortunately, we did not figure out until very recently that the bug occurs only when two such sequences are queued up back-to-back in AME. As a result, although we had the bug on the books, we were missing one of the keys to reproducing it reliably, and at one point when we could not repro the hang we wrongly concluded that it was fixed. By the time we discovered that the bug was still present and nailed down the critical detail, it was too late to fix it for the next release. Our developers are working on a fix now.
                                                      Incidentally, although the bug manifests in AME, it actually results from an issue on the Premiere side. That means that if the fix makes it into a patch--and let me emphasize the "if" because I can make no promises--then it will be in an update to PPRO, not AME.
                                                      I know I posted this workaround before, but it's worth repeating: if your PPRO sequence(s) contain stills >1920x1080, avoid queuing multiple jobs. Either wait until Job X is done before exporting Job Y, or go ahead and export Job Y but then set its status to Skip through the Edit menu or context menu. And, of course, as you pointed out, BigArm, scaling the source assets also works.
                                                      • 224. Re: Media Encoder Stops Encoding with the New CS5.5
                                                        That may reproduce the bug many of the reported cases, but in my case I had no stills whatsoever in any of my sequences. (See my post March 26, 2012).
                                                        • 225. Re: Media Encoder Stops Encoding with the New CS5.5
                                                          staheph1
                                                          I am having the same problem with a project with stills >1920x1080, but only one job at a time.
                                                          Just exporting one by one is not the solution. Encoding stops randomly, no error message or "not responding"
                                                          Same occures if exported via AME or PP directly.
                                                          After 2 hours of idling I abort the encoding. Message from AME: "Encoding is running, do you really want to quit?" (CPU load 2%, RAM at 2.9GB)
                                                          scaling the stills is not an option since I want to zoom in without loosing resolution.
                                                          Windows 7 Ultimate Service Pack 1 64bit
                                                          Intel Core 2 Quad CPU Q9550 @ 2.83 Ghz
                                                          8GB RAM (RAM usage never goes beyond 4.5GB, eventough lots of free RAM is listed, 1.5GB reserved for other applications than Adobe)
                                                          Production Premium: Premiere Pro CS 5.5
                                                          Project:
                                                          Lengh 4.5 Minutes
                                                          Timelapse of 12000 stills (38GB)
                                                          at 2592*1944 2.8MB each.
                                                          Sound with .mp3 file
                                                          Export:
                                                          Video: NTCS, 1280x720 or 1920*1080 29.97fps, Quality 4, Progressive
                                                          Audio: MPEG, 384Kbit/s, 84kHz, 16bit, Stereo
                                                          Bitrate: VBR, 1-Pass, Min. 4.00, Target 10.00, Max. 18.50 Mbit/s
                                                          • 226. Re: Media Encoder Stops Encoding with the New CS5.5
                                                            I think you should be ok if you turn mercury render engine off.  It will be a lot slower, but should get through it I think.
                                                            • 227. Re: Media Encoder Stops Encoding with the New CS5.5
                                                              RFendelman Level 1
                                                              Sorry to off subject, but have you found a way to 'bulk' change the length of a group of stills without having to re-import them?
                                                              Sent from my iPhone
                                                              • 228. Re: Media Encoder Stops Encoding with the New CS5.5
        staheph1 Level 1
        I have a Nidia GTX 280 which is not supported.
        I dont even get the choice to  enable GPU support.
        It must be turned off by default..
        Richard Fendelman:
        I am not sure what you mean.
        If you import stills via the menu and import, you can click on the first still in a folder and click on "continous file number" or so,
        then all the still are being imported as one element, each still being 1 frame.
        I contacted you via private message to not spam this topic here.
        Message was edited by: staheph1
        • 229. Re: Media Encoder Stops Encoding with the New CS5.5
        Paul_Duffey Level 1
        Yeah if your gpu is not supported then the option to select gpu cuda rendering is not available. The thing is for a project like you have you really need to get a supported card. With a system with that low of specs, you may have a computer with a 5400 drive. Those two things alone right now are what's holding you back. Go ahead and get a GTX 570 off ebay for a couple hundred, you can use it in your next system when you upgrade too. The rest of your system should be fine if you don't do a lot of rendering, or just a couple times a year. If you're doing something like this for a living, making money, and you're rendering several hours a week, then I'd recommend getting a system with an i7 processor which is going to give you 4 more rendering cores, 8 more if you get the i7 970 or 980.
        • 230. Re: Media Encoder Stops Encoding with the New CS5.5
        staheph1 Level 1
        I am working off a SSD Drive, project data and everything is on there.
        The slower cpu and no gpu support MUST NOT make the program
        stop rendering, maybe go slower but not "freeze" like that.
        I have a 7.3 Windowsrating (that doesn't say much I know), but at
        least it should make PP run stable.
        • 231. Re: Media Encoder Stops Encoding with the New CS5.5
        Paul_Duffey Level 1
        I think PP running stable is a grey area. It has a lot to do with how much horsepower it takes to render some things and also could be related to other drivers in your system. I'd update windows, update pp if you haven't already, update your card's driver if you haven't decide to upgrade your card yet. Also if everything is running off of one SSD that might not be the best. You want your source and render folders to be on two different drives, that will help with bottlenecking of data. Also there are many different types of drives, setups, and drivers for your ssd drive even. I know some have trouble with trimming, which can also cause slow writes, which could intern cause PP to have problems.
        • 232. Re: Media Encoder Stops Encoding with the New CS5.5
        creazer Level 1
        Hi Mark. I've just finished reading a lot of the posts on this forum and have been having similar problems with my system. Could you please let me know if there is a fix for this problem?
        Thank you.
        • 233. Re: Media Encoder Stops Encoding with the New CS5.5
        Kent Purdy Level 1
        Saad,
        I have the original problem of this thread, AME stopping randomly during a long conversion,using MPEusing PP CS5.5 & CS6, (CS5.03 works flawlessly, and still does).Ive found three workarounds, first and foremost is to reset Win7 performance settings to "Adjust for best performance". This takes a load off the GPU.(My Gpu runs 10 degrees cooler) Second is, depending how long the project is, I will break it into two or three segments to render out.Im working with BD only,so the files are quite large.Encore CS6 will put them together so there is no pause at a break.(Previous versions did not do such a good job).
        Third, and Im not sure this has anything to do with the workaround, is to leave PP open during AMEs' work.( I used to close out PP thinking it saved resources for Encore,it dosent).I think this problem is all to do with the Nvidia card GPU, not the drivers (Ive always had the most current drivers).Any thing to lighten the load on the GPU will help. I have just encoded a ten hour BD project into three files without a glitch.
        I hope this will help you.
        Kent
        • 234. Re: Media Encoder Stops Encoding with the New CS5.5
        creazer Level 1
        hi Kent. Thanks for getting back to me. I will definitel go through and test that which you've suggested. What if I don't have CS6 yet? I won't be getting CS6 for another 3 months. Is there another way around that?
        Also, here are some screen shots of my hardware...
        • 235. Re: Media Encoder Stops Encoding with the New CS5.5
        Kent Purdy Level 1
        Saad, What ver of PP are you using?
        Kent
        • 236. Re: Media Encoder Stops Encoding with the New CS5.5
        creazer Level 1
        Hi Kent. Sorry. Premiere CS5.5
        • 237. Re: Media Encoder Stops Encoding with the New CS5.5
        Kent Purdy Level 1
        Saad, I skipped CS5.5 (although I did try it) when others were having the same problem and stayed with 5.03.I thought CS6 would fix the problem but it didnt (for me). Thats when I started looking seriously for a workaround. I think my workaround would work on CS5.Good luck.
        Kent
        • 238. Re: Media Encoder Stops Encoding with the New CS5.5
        creazer Level 1
        Hi Kent. I did some tests with exporting directly from Premiere(without opening AME) and it worked. I've just finished building my raid 5 and copying some files accross. I will try encoding with AME with Premiere still open in the background. I hope it works. :-)
        • 239. Re: Media Encoder Stops Encoding with the New CS5.5
        Kent Purdy Level 1
        Saad, Thats great news, I saw in another forum you were having an issue with the audio file, when encoding for a BD. I am also having a problem.Pro Pro shortings ths audio by 18 seconds. Unusable. Have you found a fix?
        Kent
