5 Replies Latest reply on May 24, 2011 3:00 PM by the_wine_snob
    Export to DVD - moving in video is "flipping"
    Lutzrahe
      Again finishing my project
      Export to DVD and now looking on TV (~40min long)
      but:
      if camera moves, the pictures is very bad, like flipping (moving very fast between 2 pictures)
      what is this?
      In the source, the move is clear, but not on the DVD
      what to do?
      Greetings
      Lutz
        • 1. Re: Export to DVD - moving in video is "flipping"
          the_wine_snob Level 9
          Lutz,
          The MPEG-2 Encoding is not the ultimate with footage involving motion, either camera, or subject motion. However, it sounds like you could have Field Reversal issues going on, as this sounds like more than just the MPEG-2 CODEC (used for DVD's).
          Can you tell us the full specs. of your Source Footage, how you Imported/Captured it into PrE, plus what your Project Preset (at New Project) is?
          That info might tip off someone as to the likelihood of Field Reversal.
          Thanks for the info and good luck,
          • 2. Re: Export to DVD - moving in video is "flipping"
            Lutzrahe Level 1
            the video source is: iphone 4 (full hd I think)
            Then copied via "windows live" to PC (no conversion)
            after that into "organizer" and into Premiere Elements (imported files and folders)
            New projekt is: PAL standart 48 khz
            Lutz
            in "preview" there is no "flipping"
            • 3. Re: Export to DVD - moving in video is "flipping"
              What sort of files are produced by the iPhone? I am guessing that the wrapper is either MOV, or MP4, but do not know for sure, and also do not know the CODEC used.
              You should be able to use either MediaInfo, or G-Spot to get the full specs. of one of those files, including the Field Order.
              • 4. Re: Export to DVD - moving in video is "flipping"
                Lutzrahe Level 1
                These are the informtion
                Allgemein
                Complete name                    : C:\Users\lr\Pictures\Salzburg\IMG_0084.MOV
                Format                           : MPEG-4
                Format profile                   : QuickTime
                Codec ID                         : qt
                File size                        : 23,9 MiB
                Duration                         : 18s 529ms
                Overall bit rate                 : 10,8 Mbps
                Encoded date                     : UTC 2011-05-13 04:21:32
                Tagged date                      : UTC 2011-05-13 04:21:45
                Writing library                  : Apple QuickTime
                Video
                Format                           : AVC
                Format/Info                      : Advanced Video Codec
                Format profile                   : Baseline@L3.1
                Format settings, CABAC           : Nein
                Format settings, ReFrames        : 1 frame
                Codec ID                         : avc1
                Codec ID/Info                    : Advanced Video Coding
                Duration                         : 18s 519ms
                Bit rate mode                    : variabel
                Bit rate                         : 10,7 Mbps
                Width                            : 1 280 Pixel
                Height                           : 720 Pixel
                Display aspect ratio             : 16:9
                Rotation                         : 180°
                Frame rate mode                  : variabel
                Frame rate                       : 29,970 FPS
                Minimum frame rate               : 28,571 FPS
                Maximum frame rate               : 30,000 FPS
                Color space                      : YUV
                Chroma subsampling               : 4:2:0
                Bit depth                        : 8 bits
                Scan type                        : progressiv
                Bits/(Pixel*Frame)               : 0.389
                Stream size                      : 23,7 MiB (99%)
                Title                            : Core Media Video
                colour_primaries                 : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
                transfer_characteristics         : BT.709-5, BT.1361
                matrix_coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
                Audio
                Format                           : AAC
                Format/Info                      : Advanced Audio Codec
                Format profile                   : LC
                Codec ID                         : 40
                Bit rate mode                    : konstant
                Bit rate                         : 64,0 Kbps
                Channel(s)                       : 1 Kanal
                Channel positions                : Front: C
                Sampling rate                    : 44,1 KHz
                Stream size                      : 145 KiB (1%)
                Title                            : Core Media Audio
                • 5. Re: Export to DVD - moving in video is "flipping"
                  OK, looks like you have H.264 in an AVC wrapper.
                  You are also starting with HD material, and down-rezzing it to DVD with the MPEG-2 CODEC, so a quality loss will take place.
                  What is your Project Preset for that material?
                  The Audio, being AAC, could be an issue. Adobe programs have issues with AAC, though the files often work.
                  If faced with AAC, and the knowledge that they can be problematic, I would rip the Audio stream, in a program, like Audacity, and then Save it as a PCM/WAV @ 48KHz 16-bit, Import that, and use it instead of teh muxed Audio stream.
