0 Replies Latest reply on May 24, 2011 2:16 PM by Hot Studmuffin
    Crash while entering edit mode
    Hot Studmuffin
      Hey all,
      I've written a script that walks the library of an fla and exports images and sounds based on type.  I've run this script on both windows and mac, and with enough time parsing a big fla, cs5 eventually crashes.  I'm trying to determine if there is something I can do to prevent this from occurring, and thus far I haven't been able to.
      This particular crash seems to occur after I try adding an item to another document and then editing the item, like so:
      tempDoc.addItem({x:0, y:0}, libraryItem);
      fl.setActiveWindow(tempDoc);
      tempDoc.selectAll();
      tempDoc.enterEditMode("");
      With a beefy SymbolItem, flash hangs for a little bit to transfer all the data over to my tempDoc, and when I enterEditMode, it sometimes crashes.  Does anyone perhaps know what may be causing this?  Here is one of my crash logs:
      Process:         Adobe Flash CS5 [12389]
      Path:            /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5
      Identifier:      com.adobe.flash
      Version:         11.0.0.485 (11.0.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [94]
      Date/Time:       2011-05-24 11:20:10.416 -0700
      OS Version:      Mac OS X 10.6.7 (10J869)
      Report Version:  6
      Interval Since Last Report:          75797 sec
      Crashes Since Last Report:           48
      Per-App Interval Since Last Report:  68848 sec
      Per-App Crashes Since Last Report:   46
      Anonymous UUID:
      Exception Type:  EXC_BAD_ACCESS (SIGBUS)
      Exception Codes: KERN_PROTECTION_FAILURE at 0x000000000000000c
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Application Specific Information:
      Java information:
      Exception type: Bus Error (0xa) at pc=00000000000085b6
      Java VM: Java HotSpot(TM) Client VM (19.1-b02-334 mixed mode macosx-x86)
      Current thread (000000002e800000):  JavaThread "main" [_thread_in_native, id=-1608805056, stack(00000000bf800000,00000000c0000000)]
      Stack: [00000000bf800000,00000000c0000000]
      Java Threads: ( => current thread )
        000000002e0e2800 JavaThread "Thread-4" [_thread_blocked, id=-1302142976, stack(00000000b252e000,00000000b262e000)]
        000000002e887400 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1314328576, stack(00000000b198f000,00000000b1a8f000)]
        000000002e887000 JavaThread "Code Model Worker" daemon [_thread_blocked, id=-1315385344, stack(00000000b188d000,00000000b198d000)]
        000000002e871400 JavaThread "FelixPackageAdmin" daemon [_thread_blocked, id=-1316442112, stack(00000000b178b000,00000000b188b000)]
        000000002e871000 JavaThread "FelixStartLevel" daemon [_thread_blocked, id=-1318518784, stack(00000000b1590000,00000000b1690000)]
        000000002e142400 JavaThread "FelixDispatchQueue" [_thread_blocked, id=-1319575552, stack(00000000b148e000,00000000b158e000)]
        000000002e828400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1321689088, stack(00000000b128a000,00000000b138a000)]
        000000002e81ec00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1322745856, stack(00000000b1188000,00000000b1288000)]
        000000002e81e000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1324662784, stack(00000000b0fb4000,00000000b10b4000)]
        000000002e81d000 JavaThread "Surrogate Locker Thread (CMS)" daemon [_thread_blocked, id=-1328496640, stack(00000000b0c0c000,00000000b0d0c000)]
        000000002e814000 JavaThread "Finalizer" daemon [_thread_blocked, id=-1329553408, stack(00000000b0b0a000,00000000b0c0a000)]
        000000002e813000 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1330610176, stack(00000000b0a08000,00000000b0b08000)]
      =>000000002e800000 JavaThread "main" [_thread_in_native, id=-1608805056, stack(00000000bf800000,00000000c0000000)]
      Other Threads:
        000000002e09a000 VMThread [stack: 00000000b0906000,00000000b0a06000] [id=-1331666944]
        000000002e83a400 WatcherThread [stack: 00000000b138c000,00000000b148c000] [id=-1320632320]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      par new generation   total 14784K, used 10568K [0000000031010000, 0000000032010000, 0000000032010000)
        eden space 13184K,  73% used [0000000031010000, 000000003197bfa8, 0000000031cf0000)
        from space 1600K,  57% used [0000000031e80000, 0000000031f66340, 0000000032010000)
        to   space 1600K,   0% used [0000000031cf0000, 0000000031cf0000, 0000000031e80000)
      concurrent mark-sweep generation total 49152K, used 11028K [0000000032010000, 0000000035010000, 0000000039010000)
      concurrent-mark-sweep perm gen total 12288K, used 8252K [0000000039010000, 0000000039c10000, 000000003d010000)
      Virtual Machine Arguments:
      JVM Args: -Djava.awt.headless=true -Xmx128m
      Java Command: <unknown>
      Launcher Type: generic
      Physical Memory: Page Size = 4k, Total = 3840M, Free = 140M
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   com.adobe.flash               0x000085b6 CObject::IsKindOf(CRuntimeClass*) const + 18
      1   com.adobe.flash               0x00398892 std::vector<int, std::allocator<int> >::insert(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator<int> > >, int const&) + 12008
      2   com.adobe.flash               0x003988b7 std::vector<int, std::allocator<int> >::insert(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator<int> > >, int const&) + 12045
      3   com.adobe.flash               0x0094fa3b boost::intrusive_ptr<dvaui::controls::UI_ListBox>::operator=(boost::intrusive_ptr<dvaui:: controls::UI_ListBox> const&) + 69579
      4   com.adobe.flash               0x00951815 boost::intrusive_ptr<dvaui::controls::UI_ListBox>::operator=(boost::intrusive_ptr<dvaui:: controls::UI_ListBox> const&) + 77221
      5   ...ia.Flash Player.authplaylib 0x20a47330 0x208fb000 + 1360688
      6   ...ia.Flash Player.authplaylib 0x20ace6da 0x208fb000 + 1914586
      7   ...ia.Flash Player.authplaylib 0x20e25dcc ExternalPlayer_Initialize + 919324
      8   ???                           0x7c1d21ca 0 + 2082283978
      9   ???                           0x7cd631a3 0 + 2094412195
      10  ???                           0x7ae14d98 0 + 2061585816
      11  ???                           0x7cd49467 0 + 2094306407
      12  ...ia.Flash Player.authplaylib 0x20e246ff ExternalPlayer_Initialize + 913487
      13  ...ia.Flash Player.authplaylib 0x20e0baaf ExternalPlayer_Initialize + 812031
      14  ...ia.Flash Player.authplaylib 0x20e25dcc ExternalPlayer_Initialize + 919324
      15  ???                           0x7c1d7686 0 + 2082305670
      16  ???                           0x7c1d7b9e 0 + 2082306974
      17  ???                           0x7c1d5869 0 + 2082297961
      18  ...ia.Flash Player.authplaylib 0x209d2683 0x208fb000 + 882307
      19  ...ia.Flash Player.authplaylib 0x209d4fe5 0x208fb000 + 892901
      20  ...ia.Flash Player.authplaylib 0x20c2ecd1 0x208fb000 + 3357905
      21  ...ia.Flash Player.authplaylib 0x20d4d60a ExternalPlayer_Initialize + 32602
      22  com.adobe.flash               0x0095899c std::vector<MCharacter*, std::allocator<MCharacter*> >::push_back(MCharacter* const&) + 6106
      23  com.adobe.flash               0x00942208 boost::intrusive_ptr<dvaui::controls::UI_ListBox>::operator=(boost::intrusive_ptr<dvaui:: controls::UI_ListBox> const&) + 14232
      24  com.adobe.flash               0x0094a5f8 boost::intrusive_ptr<dvaui::controls::UI_ListBox>::operator=(boost::intrusive_ptr<dvaui:: controls::UI_ListBox> const&) + 48008
      25  com.adobe.flash               0x001accc1 CSketchViewPrintContext::CSketchViewPrintContext() + 168837
      26  com.adobe.flash               0x00184ca8 CSketchViewPrintContext::CSketchViewPrintContext() + 4972
      27  com.adobe.flash               0x00d7c2e3 non-virtual thunk to CStdioFile::~CStdioFile() + 12457
      28  com.adobe.flash               0x00da77d8 non-virtual thunk to LScroller::ListenToMessage(long, void*) + 8292
      29  com.adobe.flash               0x00da780b non-virtual thunk to LScroller::ListenToMessage(long, void*) + 8343
      30  com.adobe.flash               0x00da780b non-virtual thunk to LScroller::ListenToMessage(long, void*) + 8343
      31  com.adobe.flash               0x00d41d1e CControlBar::GetRuntimeClass() const + 810
      32  com.adobe.flash               0x00e0879a non-virtual thunk to LCarbonApp::MakeSelfSpecifier(AEDesc&, AEDesc&) const + 698
      33  com.apple.HIToolbox           0x962c8c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      34  com.apple.HIToolbox           0x962c7ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      35  com.apple.HIToolbox           0x962ea7f3 SendEventToEventTarget + 52
      36  com.apple.HIToolbox           0x962fb0f9 SendEvent(unsigned long, WindowData*, OpaqueRgnHandle*) + 203
      37  com.apple.HIToolbox           0x962faf84 PaintWindow(WindowData*, OpaqueRgnHandle*, PaintReason, bool) + 495
      38  com.apple.HIToolbox           0x962eddd8 WindowData::PrepareForVisibility() + 236
      39  com.apple.HIToolbox           0x962ed338 _ShowHideWindows + 291
      40  com.apple.HIToolbox           0x962ed212 ShowHide + 38
      41  com.adobe.owl                 0x06d766c8 OWLThemeAddBrush + 6524
      42  com.adobe.owl                 0x06e4372e OWLDocumentCreateNonComposite + 18152
      43  com.adobe.owl                 0x06e44194 OWLDocumentCreateNonComposite + 20814
      44  com.adobe.owl                 0x06d752e0 OWLThemeAddBrush + 1428
      45  com.apple.HIToolbox           0x962c8c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      46  com.apple.HIToolbox           0x962c7ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      47  com.apple.HIToolbox           0x962c7d55 SendEventToEventTargetWithOptions + 58
      48  com.adobe.owl                 0x06d74fe5 OWLThemeAddBrush + 665
      49  com.adobe.owl                 0x06d768ab OWLThemeAddBrush + 7007
      50  com.adobe.owl                 0x06e43cad OWLDocumentCreateNonComposite + 19559
      51  com.adobe.owl                 0x06e4608c OWLDocumentCreateNonComposite + 28742
      52  com.adobe.owl                 0x06e46200 OWLDocumentCreateNonComposite + 29114
      53  com.adobe.owl                 0x06e58b5d OWLWorkspaceBookmarkSnapshot + 25515
      54  com.adobe.owl                 0x06d8b4ee OWLPaletteGetIcon + 536
      55  com.adobe.owl                 0x06daf51e OWLWidgetShow + 370
      56  com.adobe.flash               0x00f1ab2e CList<MMUI::DocumentFrame*, MMUI::DocumentFrame*>::~CList() + 2426
      57  com.adobe.flash               0x00f1d33b MMUI::COwlFrameWnd::~COwlFrameWnd() + 3297
      58  com.adobe.flash               0x0052f5a3 std::vector<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> >, std::allocator<std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > > >::push_back(std::basic_string<wchar_t, std::char_traits<wchar_t>, std::allocator<wchar_t> > const&) + 17663
      59  com.adobe.flash               0x00e3b44e non-virtual thunk to LMLTEPane::DontBeTarget() + 201214
      60  com.adobe.flash               0x00e358ba non-virtual thunk to LMLTEPane::DontBeTarget() + 177770
      61  com.adobe.flash               0x00e3acf5 non-virtual thunk to LMLTEPane::DontBeTarget() + 199333
      62  com.adobe.flash               0x00e0c667 non-virtual thunk to LMLTEPane::DontBeTarget() + 9239
      63  com.adobe.flash               0x00e0c6e4 non-virtual thunk to LMLTEPane::DontBeTarget() + 9364
      64  com.adobe.flash               0x00542c17 JSInterp::EvaluateScript(JSContext*, JSObject*, unsigned short const*, unsigned int, unsigned short const*, unsigned int, long*) + 225
      65  com.adobe.flash               0x00541b9b std::vector<CSwfPanel*, std::allocator<CSwfPanel*> >::push_back(CSwfPanel* const&) + 21551
      66  com.adobe.flash               0x00542539 std::vector<CSwfPanel*, std::allocator<CSwfPanel*> >::push_back(CSwfPanel* const&) + 24013
      67  com.adobe.flash               0x0015c5dc std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> >::operator=(std::deque<CSketchSWFHistory, std::allocator<CSketchSWFHistory> > const&) + 28374
      68  com.adobe.flash               0x00756190 non-virtual thunk to CPlayerEnabledButton::UnLock() + 5356
      69  com.adobe.flash               0x00d3619b CMiniFrameWnd::~CMiniFrameWnd() + 993
      70  com.adobe.flash               0x00d67f73 non-virtual thunk to CScrollViewImpl::ListenToMessage(long, void*) + 6749
      71  com.adobe.flash               0x00d7e390 non-virtual thunk to CStdioFile::~CStdioFile() + 20822
      72  com.adobe.flash               0x00d7d63f non-virtual thunk to CStdioFile::~CStdioFile() + 17413
      73  com.adobe.flash               0x00d7a0e7 non-virtual thunk to CStdioFile::~CStdioFile() + 3757
      74  com.adobe.flash               0x00d79fb2 non-virtual thunk to CStdioFile::~CStdioFile() + 3448
      75  com.adobe.flash               0x00d7b18e non-virtual thunk to CStdioFile::~CStdioFile() + 8020
      76  com.adobe.flash               0x00d7a51c non-virtual thunk to CStdioFile::~CStdioFile() + 4834
      77  com.apple.HIToolbox           0x962c8c2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
      78  com.apple.HIToolbox           0x962c7ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      79  com.apple.HIToolbox           0x962c7d55 SendEventToEventTargetWithOptions + 58
      80  com.apple.HIToolbox           0x962fca24 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 3006
      81  com.apple.HIToolbox           0x962c9080 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
      82  com.apple.HIToolbox           0x962c7ef6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
      83  com.apple.HIToolbox           0x962ea7f3 SendEventToEventTarget + 52
      84  com.apple.HIToolbox           0x96473c17 ToolboxEventDispatcher + 86
      85  com.apple.HIToolbox           0x96473d4f RunApplicationEventLoop + 243
      86  com.adobe.flash               0x00d6f8ba non-virtual thunk to CFileDialogImpl::~CFileDialogImpl() + 4302
      87  com.adobe.flash               0x00d460df CTimerImpl::~CTimerImpl() + 297
      88  com.adobe.flash               0x00d4618b CTimerImpl::~CTimerImpl() + 469
      89  com.adobe.flash               0x00004036 0x1000 + 12342
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x91855922 kevent + 10
      1   libSystem.B.dylib             0x9185603c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x918554f9 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x9185529e _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x91854d21 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x91854b66 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x9182f0e2 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib             0x9185cc9c _pthread_cond_wait + 1089
      2   libSystem.B.dylib             0x918a545f pthread_cond_wait + 48
      3   com.adobe.amt.services        0x0af2d126 AMTConditionLock::LockWhenCondition(int) + 46
      4   com.adobe.amt.services        0x0af25db0 _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 116
      5   com.adobe.amt.services        0x0af2d18c AMTThread::Worker(void*) + 24
      6   libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      7   libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 3:
      0   libSystem.B.dylib             0x9185d046 __semwait_signal + 10
      1   libSystem.B.dylib             0x9185cd02 _pthread_cond_wait + 1191
      2   libSystem.B.dylib             0x9185e998 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore 0x975d648e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore 0x975c1e15 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore 0x975bd7e3 MPWaitOnQueue + 250
      6   AdobeACE                      0x053386f1 0x52fe000 + 239345
      7   AdobeACE                      0x053380ed 0x52fe000 + 237805
      8   ...ple.CoreServices.CarbonCore 0x975a17ca PrivateMPEntryPoint + 68
      9   libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      10  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 4:
      0   libSystem.B.dylib             0x9186c5d2 recvfrom$UNIX2003 + 10
      1   libSystem.B.dylib             0x9188c3a7 recv$UNIX2003 + 54
      2   ServiceManager-Launcher.dylib 0x218ad6cf Invoke + 54887
      3   ServiceManager-Launcher.dylib 0x218ac76e Invoke + 50950
      4   ServiceManager-Launcher.dylib 0x218ab61f Invoke + 46519
      5   ServiceManager-Launcher.dylib 0x218ab671 Invoke + 46601
      6   ServiceManager-Launcher.dylib 0x218ab6fb Invoke + 46739
      7   ServiceManager-Launcher.dylib 0x218a5afe Invoke + 23190
      8   ServiceManager-Launcher.dylib 0x218a5ce7 Invoke + 23679
      9   ServiceManager-Launcher.dylib 0x218a68c7 Invoke + 26719
      10  ServiceManager-Launcher.dylib 0x218a69c5 Invoke + 26973
      11  ServiceManager-Launcher.dylib 0x218a9db0 Invoke + 40264
      12  ServiceManager-Launcher.dylib 0x218aa059 Invoke + 40945
      13  ServiceManager-Launcher.dylib 0x218aa687 Invoke + 42527
      14  ServiceManager-Launcher.dylib 0x218aa884 Invoke + 43036
      15  ServiceManager-Launcher.dylib 0x2189c826 Login + 1654
      16  ServiceManager-Launcher.dylib 0x2189dc71 Login + 6849
      17  ServiceManager-Launcher.dylib 0x218aadf3 Invoke + 44427
      18  ServiceManager-Launcher.dylib 0x218ad341 Invoke + 53977
      19  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      20  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 5:  Java: Exception Handler Thread
      0   libSystem.B.dylib             0x9182f09a mach_msg_trap + 10
      1   libSystem.B.dylib             0x9182f807 mach_msg + 68
      2   libSystem.B.dylib             0x9189b078 mach_msg_server + 520
      3   libjvm.dylib                  0x2d80fa6d JNI_CreateJavaVM_Impl + 56194
      4   libjvm.dylib                  0x2d80fa18 JNI_CreateJavaVM_Impl + 56109
      5   libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      Thread 6:  Java: Gang worker#0 (Parallel GC Threads)
      2   libjvm.dylib                  0x2da83aa9 JVM_RaiseSignal + 361175
      3   libjvm.dylib                  0x2d80ee6e JNI_CreateJavaVM_Impl + 53123
      4   libjvm.dylib                  0x2da786c1 JVM_RaiseSignal + 315119
      5   libjvm.dylib                  0x2da78790 JVM_RaiseSignal + 315326
      6   libjvm.dylib                  0x2d80eabb JNI_CreateJavaVM_Impl + 52176
      7   libjvm.dylib                  0x2d822fd2 jio_vsnprintf + 331
      8   libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      Thread 7:  Java: Gang worker#1 (Parallel GC Threads)
      Thread 8:  Java: Concurrent Mark-Sweep GC Thread
      2   libjvm.dylib                  0x2da83b79 JVM_RaiseSignal + 361383
      3   libjvm.dylib                  0x2da83f1c JVM_RaiseSignal + 362314
      4   libjvm.dylib                  0x2da786db JVM_RaiseSignal + 315145
      7   libjvm.dylib                  0x2d8afa3b JVM_Write + 3519
      8   libjvm.dylib                  0x2d8af9b7 JVM_Write + 3387
      9   libjvm.dylib                  0x2d828db7 jio_vsnprintf + 24368
      10  libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      11  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      12  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 9:  Java: VM Thread
      7   libjvm.dylib                  0x2d88af44 JVM_Lseek + 139010
      8   libjvm.dylib                  0x2d88abf4 JVM_Lseek + 138162
      9   libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      10  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      11  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 10:  Java: Reference Handler
      4   libjvm.dylib                  0x2dabe58a JVM_RaiseSignal + 601528
      5   libjvm.dylib                  0x2dabe9ed JVM_RaiseSignal + 602651
      6   libjvm.dylib                  0x2d896002 JVM_MonitorWait + 221
      7   libjvmlinkage.dylib           0x22f19e75 JVM_MonitorWait + 69
      8   ???                           0x2f00b9d9 0 + 788576729
      9   ???                           0x2f003e31 0 + 788545073
      10  ???                           0x2f003e31 0 + 788545073
      11  ???                           0x2f001374 0 + 788534132
      12  libjvm.dylib                  0x2d88c1be JVM_Lseek + 143740
      13  libjvm.dylib                  0x2d88bf66 JVM_Lseek + 143140
      14  libjvm.dylib                  0x2d895de9 JVM_StartThread + 2639
      15  libjvm.dylib                  0x2d895cee JVM_StartThread + 2388
      16  libjvm.dylib                  0x2d895c7d JVM_StartThread + 2275
      17  libjvm.dylib                  0x2d895af0 JVM_StartThread + 1878
      18  libjvm.dylib                  0x2d89599f JVM_StartThread + 1541
      19  libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      20  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      21  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 11:  Java: Finalizer
      10  ???                           0x2f003f97 0 + 788545431
      11  ???                           0x2f003f97 0 + 788545431
      12  ???                           0x2f001374 0 + 788534132
      13  libjvm.dylib                  0x2d88c1be JVM_Lseek + 143740
      14  libjvm.dylib                  0x2d88bf66 JVM_Lseek + 143140
      15  libjvm.dylib                  0x2d895de9 JVM_StartThread + 2639
      16  libjvm.dylib                  0x2d895cee JVM_StartThread + 2388
      17  libjvm.dylib                  0x2d895c7d JVM_StartThread + 2275
      18  libjvm.dylib                  0x2d895af0 JVM_StartThread + 1878
      19  libjvm.dylib                  0x2d89599f JVM_StartThread + 1541
      20  libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      21  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      22  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 12:  Java: Surrogate Locker Thread (CMS)
      6   libjvm.dylib                  0x2d80ea02 JNI_CreateJavaVM_Impl + 51991
      7   libjvm.dylib                  0x2d8a7b03 JVM_IsPrimitiveClass + 5163
      Thread 13:  Java: Signal Dispatcher
      0   libSystem.B.dylib             0x9182f0d6 semaphore_wait_trap + 10
      1   libjvm.dylib                  0x2d8a8729 JVM_IsPrimitiveClass + 8273
      2   libjvm.dylib                  0x2d8a8162 JVM_IsPrimitiveClass + 6794
      3   libjvm.dylib                  0x2d895af0 JVM_StartThread + 1878
      4   libjvm.dylib                  0x2d89599f JVM_StartThread + 1541
      Thread 14:  Java: CompilerThread0
      7   libjvm.dylib                  0x2d8af5cf JVM_Write + 2387
      8   libjvm.dylib                  0x2d8a97c4 JVM_IsPrimitiveClass + 12524
      9   libjvm.dylib                  0x2d895af0 JVM_StartThread + 1878
      10  libjvm.dylib                  0x2d89599f JVM_StartThread + 1541
      11  libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      12  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      13  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 15:  Java: Low Memory Detector
      7   libjvm.dylib                  0x2d8aaec6 JVM_IsPrimitiveClass + 18414
      Thread 16:  Java: VM Periodic Task Thread
      3   libjvm.dylib                  0x2da8410b JVM_RaiseSignal + 362809
      4   libjvm.dylib                  0x2d8aca14 JVM_IsPrimitiveClass + 25404
      Thread 17:  Java: FelixDispatchQueue
      11  ???                           0x2f003e31 0 + 788545073
      12  ???                           0x2f003e31 0 + 788545073
      13  ???                           0x2f00430d 0 + 788546317
      14  ???                           0x2f001374 0 + 788534132
      15  libjvm.dylib                  0x2d88c1be JVM_Lseek + 143740
      16  libjvm.dylib                  0x2d88bf66 JVM_Lseek + 143140
      17  libjvm.dylib                  0x2d895de9 JVM_StartThread + 2639
      18  libjvm.dylib                  0x2d895cee JVM_StartThread + 2388
      19  libjvm.dylib                  0x2d895c7d JVM_StartThread + 2275
      20  libjvm.dylib                  0x2d895af0 JVM_StartThread + 1878
      21  libjvm.dylib                  0x2d89599f JVM_StartThread + 1541
      22  libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      23  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      24  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 18:  Java: FelixStartLevel
      11  ???                           0x2f00430d 0 + 788546317
      Thread 19:  Java: FelixPackageAdmin
      Thread 20:  Java: Code Model Worker
      3   libjvm.dylib                  0x2da83def JVM_RaiseSignal + 362013
      4   libjvm.dylib                  0x2d916d25 JVM_ActiveProcessorCount + 300
      5   ???                           0x2f00b9d9 0 + 788576729
      6   ???                           0x2f003e31 0 + 788545073
      7   ???                           0x2f003e31 0 + 788545073
      8   ???                           0x2f00430d 0 + 788546317
      9   ???                           0x2f004473 0 + 788546675
      Thread 21:  Java: Code Model Worker
      Thread 22:
      1   libSystem.B.dylib             0x91888ec5 nanosleep$UNIX2003 + 188
      2   com.adobe.flash.flbridge      0x23c2cd4b ScObjects::Thread::sleep(unsigned int) + 59
      3   com.adobe.flash.flbridge      0x23c272d3 ScObjects::BridgeTalkThread::run() + 163
      4   com.adobe.flash.flbridge      0x23c2ce58 ScObjects::Thread::go(void*) + 168
      5   libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      6   libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 23:
      3   ...ia.Flash Player.authplaylib 0x20d1e31f 0x208fb000 + 4338463
      4   ...ia.Flash Player.authplaylib 0x209146ef 0x208fb000 + 104175
      5   ...ia.Flash Player.authplaylib 0x20d1e40c 0x208fb000 + 4338700
      6   ...ia.Flash Player.authplaylib 0x20d1e450 0x208fb000 + 4338768
      7   ...ia.Flash Player.authplaylib 0x20d1e53b 0x208fb000 + 4339003
      8   libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      9   libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 24:
      Thread 25:  com.apple.CFSocket.private
      0   libSystem.B.dylib             0x9184e066 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation      0x950dac83 __CFSocketManager + 1091
      Thread 26:
      3   com.adobe.adobeswfl           0x3dfd0d5f APXGetHostAPI + 2567887
      4   com.adobe.adobeswfl           0x3dd721ef APXGetHostAPI + 82783
      5   com.adobe.adobeswfl           0x3dfd0e4c APXGetHostAPI + 2568124
      6   com.adobe.adobeswfl           0x3dfd0eb7 APXGetHostAPI + 2568231
      7   com.adobe.adobeswfl           0x3dfd0f9b APXGetHostAPI + 2568459
      Thread 27:
      Thread 28:
      0   libSystem.B.dylib             0x9182f0fa semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x9185cc85 _pthread_cond_wait + 1066
      2   libSystem.B.dylib             0x9188baa8 pthread_cond_timedwait_relative_np + 47
      3   com.adobe.adobeswfl           0x3dfd0d27 APXGetHostAPI + 2567831
      4   com.adobe.adobeswfl           0x3e1460d8 APXGetHostAPI + 4096584
      Thread 29:
      4   com.adobe.adobeswfl           0x3dfeb6de APXGetHostAPI + 2676814
      Thread 30:
      2   com.apple.CoreFoundation      0x9509b37f __CFRunLoopRun + 2079
      3   com.apple.CoreFoundation      0x9509a464 CFRunLoopRunSpecific + 452
      4   com.apple.CoreFoundation      0x9509a291 CFRunLoopRunInMode + 97
      5   com.apple.Foundation          0x97b076f4 +[NSURLConnection(NSURLConnectionReallyInternal) _resourceLoadLoop:] + 329
      6   com.apple.Foundation          0x97acead0 -[NSThread main] + 45
      7   com.apple.Foundation          0x97acea80 __NSThread__main__ + 1499
      Thread 31:  Java: Thread-4
      3   libjvm.dylib                  0x2da8404b JVM_RaiseSignal + 362617
      4   libjvm.dylib                  0x2d8dee60 JVM_Sleep + 267
      5   libjvmlinkage.dylib           0x22f1aa68 JVM_Sleep + 72
      6   ???                           0x2f00b9d9 0 + 788576729
      9   ???                           0x2f001374 0 + 788534132
      10  libjvm.dylib                  0x2d88c1be JVM_Lseek + 143740
      11  libjvm.dylib                  0x2d88bf66 JVM_Lseek + 143140
      12  libjvm.dylib                  0x2d895de9 JVM_StartThread + 2639
      13  libjvm.dylib                  0x2d895cee JVM_StartThread + 2388
      14  libjvm.dylib                  0x2d895c7d JVM_StartThread + 2275
      15  libjvm.dylib                  0x2d895af0 JVM_StartThread + 1878
      16  libjvm.dylib                  0x2d89599f JVM_StartThread + 1541
      17  libjvm.dylib                  0x2d80e8e9 JNI_CreateJavaVM_Impl + 51710
      18  libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      19  libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 32:
      4   com.apple.CoreFoundation      0x950a03a4 CFRunLoopRun + 84
      5   com.apple.DesktopServices     0x95d37c7d TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
      6   ...ple.CoreServices.CarbonCore 0x975a17ca PrivateMPEntryPoint + 68
      7   libSystem.B.dylib             0x9185c7fd _pthread_start + 345
      8   libSystem.B.dylib             0x9185c682 thread_start + 34
      Thread 33:
      0   libSystem.B.dylib             0x918549b2 __workq_kernreturn + 10
      1   libSystem.B.dylib             0x91854f48 _pthread_wqthread + 941
      2   libSystem.B.dylib             0x91854b66 start_wqthread + 30
      Thread 34:
      2   libSystem.B.dylib             0x91888e03 usleep$UNIX2003 + 61
      3   com.apple.AppKit              0x96b20fe1 -[NSUIHeartBeat _heartBeatThread:] + 2039
      4   com.apple.Foundation          0x97acead0 -[NSThread main] + 45
      5   com.apple.Foundation          0x97acea80 __NSThread__main__ + 1499
      Thread 35:
      3   ...ia.Flash Player.authplaylib 0x20d1e2e7 0x208fb000 + 4338407
      4   ...ia.Flash Player.authplaylib 0x20ad038e 0x208fb000 + 1921934
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0xb201f000  ebx: 0x01c07e8c  ecx: 0x6f8bc950  edx: 0x00000000
        edi: 0x7316fa00  esi: 0x7fffffff  ebp: 0xbfffb8d8  esp: 0xbfffb8c0
         ss: 0x0000001f  efl: 0x00010286  eip: 0x000085b6   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x0000000c
      Binary Images:
          0x1000 -  0x17c5fe0 +com.adobe.flash 11.0.0.485 (11.0.0) <2343CC5D-89F9-6FED-DC01-7365A3714AB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/Adobe Flash CS5
      0x20e9000 -  0x2261ffb +com.adobe.PlugPlug 2.0.0.746 (2.0.0.746) <08AD22E3-34C0-6749-E497-616C66A246AD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
      0x2305000 -  0x23d2fe7 +AdobeAXEDOMCore ??? (???) <F76D74DC-FD5A-9783-C447-2E58773DA7E1> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
      0x2441000 -  0x24d2ff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x24f1000 -  0x25beff3 +libicui18n.dylib.36.0 36.0.0 (compatibility 36.0.0) <08F15219-7F35-574E-7725-1ACAA1B18A00> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUInternationalization.framework/Versions/3.6/libicui18n.dyl ib.36.0
      0x2621000 -  0x26fbfef +libicuuc.dylib.36.0 36.0.0 (compatibility 36.0.0) <5EE72009-40B3-7FB7-3A49-576AEDE0D400> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUUnicode.framework/Versions/3.6/libicuuc.dylib.36.0
      0x273b000 -  0x30ebfff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x30ee000 -  0x30f9fef +libChar16.dylib ??? (???) <0221EB9E-35A8-64CC-5A72-FC3CB24D9854> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libChar16.dylib
      0x3101000 -  0x3118fe0 +libCoreTypes.dylib ??? (???) <6CE8917C-AB39-4A09-2E6B-59C4AEF06701> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/MacOS/libCoreTypes.dylib
      0x3135000 -  0x3144fef +ZLib.dylib ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/ZLib.dylib
      0x3149000 -  0x3344ff7  com.apple.carbonframeworktemplate 1.0 (1.0) <C10F12ED-AEA6-63FA-7212-A170F37FE049> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/frameworks/Xerces.framework/Versions/A/Xerces
      0x35e6000 -  0x35eaff7  com.apple.JavaVM 13.4.0 (13.4.0) <77CA466B-7DDA-D261-53A0-312FB7B0A6DC> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
      0x35f2000 -  0x437dfe7 +com.adobe.illustrator 382 (15.0.0) <64F68532-0311-6BBA-1F50-246CAF917549> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AILib.framework/Versions/A/AILib
      0x5162000 -  0x51a6fff +com.adobe.illustrator.aiport AIPort version 1.0 (1.0) <69EDC44E-D7BB-A259-282D-C42725AE0E26> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AIPort.framework/Versions/A/AIPort
      0x5209000 -  0x524ffff +FilterPort ??? (???) <23FAE9D1-9376-1E71-21F7-D3EB2BFD50EE> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FilterPort.framework/Versions/A/FilterPort
      0x52c4000 -  0x52c4fff +SPBasic ??? (???) <5D1760D8-C910-C641-0BC9-CF74A1A5190D> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/SPBasic.framework/Versions/A/SPBasic
      0x52c8000 -  0x52e4ff9 +AdobePDFSettings ??? (???) /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
      0x52fe000 -  0x5412fff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x5435000 -  0x5937fef +AdobeAGM ??? (???) <5B8478AC-5DD0-F116-5B3E-45596CF551C6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x5a73000 -  0x5aaefff +AdobeARE ??? (???) <CEE507DA-9B96-FAF9-7894-445C427C3D7A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
      0x5ab7000 -  0x5ad1fff +AdobeBIB ??? (???) <5533CDC7-676C-0CF0-97B7-8EDD26837FFC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x5ada000 -  0x5afbff7 +AdobeBIBUtils ??? (???) <726B8463-9301-CE6C-0F2C-5CA81795A4CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x5b07000 -  0x5df9ff7 +AdobeCoolType ??? (???) <2BF62C8A-D715-FDE8-650C-1984CFFCE33C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x5e81000 -  0x6259ff7 +AdobeMPS ??? (???) <272DAEDE-FC7E-B412-7C97-CF47FF6BF242> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
      0x6388000 -  0x6466fef +AdobePDFPort ??? (???) <324E65FD-0011-F93F-9B92-FB4E17968181> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
      0x649c000 -  0x6ad0feb +AdobePDFL ??? (???) <1A619F3E-A9D4-A99C-791E-92B564F64609> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
      0x6bfc000 -  0x6c22ff6 +AdobeAXE8SharedExpat ??? (???) <5848BBCE-3A3E-66EE-5527-97A96F0CA4CC> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
      0x6c33000 -  0x6c5afed +AdobeAXE16SharedExpat ??? (???) <66F4E782-C848-AD92-686D-5A479A4B333A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
      0x6c6c000 -  0x6cc4ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
      0x6cd3000 -  0x6d40fef +FileInfo ??? (???) <4A4C74F9-CA83-B174-F56D-F7671DC61389> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x6d5b000 -  0x6efafe7 +com.adobe.owl AdobeOwl version 3.0.81 (3.0.81) <9C261D9E-9BD7-5DE6-5676-AEEF4828D17B> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x6f63000 -  0x7ca6fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <CFBCB19A-03F7-D095-1F48-8D68F05A25C5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x7fe5000 -  0x81cbff7 +com.adobe.linguistic.LinguisticManager 5.0.0 (11696) <AF804353-8B13-7180-F2C8-832361EB2D5A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
      0x8259000 -  0x825dffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
      0x8264000 -  0x851dfe7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.150919) <54AE7B13-C660-531F-B508-33372008A21E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
      0x881e000 -  0x8973fff +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.150919) <5BEA3AAE-2865-D8AF-F798-704D00DACC17> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
      0x8ac8000 -  0x8dddfe7 +com.adobe.dvaadameve.framework dvaadameve version 5.0.0 (5.0.0.150919) <AFDABF21-752A-2341-6A4E-62DA544BEA94> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
      0x92a2000 -  0x9308ffb +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <DD471011-9120-1BC2-F1B5-D6FF09D0859F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x9338000 -  0x938bffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <4F2BFF03-01D2-A07D-E5E2-7F88D4C2DEC4> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x93d3000 -  0x93e5fff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobePIP.framework/Versions/A/AdobePIP
      0x93ee000 -  0x9526fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0x9568000 -  0x956efef +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.150919) <44362FE9-5F8A-A2EE-88E4-6876D6D8507F> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
      0x957f000 -  0x958aff3 +com.adobe.boost_filesystem.framework boost_filesystem version 5.0.0 (5.0.0.150919) <27F6A491-0234-ED1A-CC83-A792D5865E97> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
      0x959e000 -  0x961cfe2 +com.adobe.boost_regex.framework boost_regex version 5.0.0 (5.0.0.150919) <4B98FD95-A873-1A50-FFC7-BC6D90759A1A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
      0x9680000 -  0x968afff +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.150919) <6D8C35A9-703F-852C-6CF0-D7DC36796BC6> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
      0x969d000 -  0x969fffb +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.150919) <CE5A959A-AA4D-5983-79B3-8C47CFDDC446> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
      0x96a7000 -  0x96aeff2 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.150919) <E752F69B-EA07-7079-CFF1-118E97A4A8FD> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
      0x96be000 -  0x984fff3 +aflamingo ??? (???) <C4136948-FE16-15C4-F1B9-040E014AF2CA> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
      0x9a12000 -  0x9a15ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x9a1b000 -  0x9b13ff7 +FlashIK Framework ??? (1.0) <3982AF5C-BAE4-1FC6-DB73-4EF99B23994A> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/FlashIK.framework/Versions/A/FlashIK
      0x9baa000 -  0x9beaffb +PFF Framework ??? (1.0) <8DB6CAC7-8E77-7FD0-140B-D60BE8D0556E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/PFF.framework/Versions/A/PFF
      0x9c17000 -  0xa613fef +aflame ??? (???) <B07806FD-0449-CBC6-FB92-0745A6D914D5> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/aflame.framework/Versions/A/aflame
      0xa7d6000 -  0xa7daff7  JavaLaunching ??? (???) <EC009D89-308A-81B9-D063-B80DA22D182F> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
      0xa7e0000 -  0xa820ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0xa839000 -  0xa8eefe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
      0xa9bd000 -  0xa9beff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0xaf08000 -  0xaf6ffea +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <EE468E2C-A6BD-E2EE-7ABE-69168B143B44> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0xafae000 -  0xafb6fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0x1fcd6000 - 0x1fd46feb +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <50675115-BEDC-72F9-C42D-374196E83EC2> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0x2038d000 - 0x2038eff7  ATSHI.dylib ??? (???) <F06AB560-C2AF-09F6-7328-773E43CA2713> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
      0x20393000 - 0x203a1fe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x203a5000 - 0x203b7ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x2056d000 - 0x20571ff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F402CF88-D96C-42A0-3207-49759F496AE8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x20576000 - 0x2057cffb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x20651000 - 0x20651fff +com.macromedia.Flash.flastoragelib 9.0 (9.0) <2A65AAC2-2EEF-8618-244A-13ECFF24E16E> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/PlugIns/FLAStorageLib.bundle/Contents/MacOS/FLAStorageLib
      0x20656000 - 0x2066aff7 +AdobeSFL ??? (???) <D6D44AC1-8AEC-56BB-8CDD-9059711B3485> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
      0x20670000 - 0x20699feb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <E0F7666B-921D-C4D6-63B3-E8B445D26892> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x206b7000 - 0x206b9ffd +com.macromedia.Flash.FLfile 11.0.0.485 (11.0.0) <5DA72BFA-D78D-94E0-0F0F-9EAC705646C6> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLfile.bundle/Contents/MacOS/FLfile
      0x208fb000 - 0x2124aff3 +com.macromedia.Flash Player.authplaylib 10.1.52.14 (1.0.1d333) <23ED9968-F20E-1132-26B1-0BC42DC14A05> /Applications/Adobe Flash CS5/Common/Configuration/AuthPlayLib.bundle/Contents/MacOS/AuthPlayLib
      0x21789000 - 0x2178eff7  libFontStreams.A.dylib 545.0.0 (compatibility 64.0.0) <5E6FE5D1-F00A-447D-8F79-E0E09A122E21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libFontStreams.A.dylib
      0x2189a000 - 0x218bdfe7 +ServiceManager-Launcher.dylib ??? (???) <12CEC4C0-8682-A5FD-BAD4-A3E4A4F6218A> /Library/Application Support/Adobe/CS5ServiceManager/lib/ServiceManager-Launcher.dylib
      0x218ca000 - 0x218e8ffb +com.adobe.flash.anemoi 11.0.0.485 (11.0.0) <0A4316BC-6FFE-C2FA-8F58-20BD7D720A40> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Air2_0.bundle/Contents/MacOS/Air2_0
      0x219b0000 - 0x219c4ffb +com.yourcompany.PointGrid ??? (1.0) <97938B0E-FD0E-BC24-12A5-90D33523249D> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/PointGrid.bundle/Contents/MacOS/PointGrid
      0x21a7f000 - 0x21ab8ffb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <C64CCBDC-B8E9-45E8-53E7-8577CFE9F2F0> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
      0x22f19000 - 0x22f20ffb  libjvmlinkage.dylib ??? (???) <CEBF52ED-6F28-BC0E-A3F6-C1CCE925FB0A> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
      0x23176000 - 0x2317dff7  libverify.dylib 1.0 (1.0) <DA039342-23CF-3CE4-63EF-CD73678B8CAC> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
      0x231b7000 - 0x231bfff7  JavaNativeFoundation ??? (???) <8260884B-94B3-A407-4D0A-7FA9C846D52E> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.fr amework/Versions/A/JavaNativeFoundation
      0x2328c000 - 0x23298ff7  libzip.jnilib ??? (???) <608DA0FD-B78D-9A0B-E754-0D060A9FAC50> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
      0x23332000 - 0x2334eff7  libjava.jnilib ??? (???) <F89A2D1A-B783-FB16-B7A7-50955C247047> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
      0x23c0c000 - 0x23c4affb +com.adobe.flash.flbridge 11.0.0.485 (11.0.0) <10AA8563-6870-61EE-1CEE-0FB603AD2BE4> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/FLBridge.bundle/Contents/MacOS/FLBridge
      0x25400000 - 0x25467ffb +com.yourcompany.Brush ??? (1.0) <25E6C744-6FCC-CF39-C01F-C14BAA743519> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Brush.bundle/Contents/MacOS/Brush
      0x26900000 - 0x2698bfeb +com.yourcompany.Collision ??? (1.0) <258F5AD8-2C92-833F-1076-105635401C53> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Collision.bundle/Contents/MacOS/Collision
      0x2b100000 - 0x2b209ff7 +com.yourcompany.Stroke ??? (1.0) <42A62A75-F5EB-27E7-47B3-B14FEABA4693> /Applications/Adobe Flash CS5/Common/Configuration/External Libraries/Stroke.bundle/Contents/MacOS/Stroke
      0x2d800000 - 0x2db31fe7  libjvm.dylib ??? (???) <7648F950-681E-B560-8629-97B4F66A492D> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libjvm. dylib
      0x3dd2e000 - 0x3eb47fc3 +com.adobe.adobeswfl ??? (2.0.0.7489) <C954CA64-9B28-A7FA-E391-C1C6524F1639> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
      0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <EF392886-5A95-6A96-C95D-43DA0322925C> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
      0x90013000 - 0x90429ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x9042a000 - 0x90473fe7  libTIFF.dylib ??? (???) <5CE284EC-F637-EDBB-FDB3-61E86407CBB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x90474000 - 0x904d5fe7  com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x904d6000 - 0x904d7ff7  com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x904d8000 - 0x90528ff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x90567000 - 0x908d2ff7  com.apple.QuartzCore 1.6.3 (227.36) <8E927524-EB0A-D5BA-C2E4-FA26FE4C428A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x908d3000 - 0x908d9fff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x908da000 - 0x90955fff  com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x90a33000 - 0x90a47fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
      0x90a61000 - 0x90a6aff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x90a6b000 - 0x90c96ff3  com.apple.QuartzComposer 4.2 ({156.28}) <08AF01DC-110D-9443-3916-699DBDED0149> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x90cca000 - 0x90cdeffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x90d2d000 - 0x90d6dff7  com.apple.ImageCaptureCore 1.0.4 (1.0.4) <CE815114-CEFA-4AF4-7365-7908428AB733> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x90d6e000 - 0x90d74fe7  com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x90d75000 - 0x90e23ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x90e24000 - 0x90e36ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x90e61000 - 0x90e61ff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x90e62000 - 0x90e68ff7  libCGXCoreImage.A.dylib 545.0.0 (compatibility 64.0.0) <218EC7C4-0520-2D8C-62EE-AA82D35448FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
      0x90e69000 - 0x90f75ff7  libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x90f76000 - 0x90f78ff7  libRadiance.dylib ??? (???) <B83179D4-E41C-D2BA-1E4C-A64CB45C15E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x90f79000 - 0x90f87fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
      0x9100d000 - 0x9100dff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x9100e000 - 0x9102afe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0x91037000 - 0x914f0ffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x914f1000 - 0x915d1fe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x917af000 - 0x917d6ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x917d7000 - 0x9182dff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x9182e000 - 0x919d5ff7  libSystem.B.dylib 125.2.10 (compatibility 1.0.0) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
      0x919d6000 - 0x91a71ff7  com.apple.ApplicationServices.ATS 4.4 (???) <FD63F92B-8DDE-4DBA-A7A5-0294E3607083> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x91a82000 - 0x91a82ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x91a83000 - 0x91a85ff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x91a86000 - 0x91d7ffef  com.apple.QuickTime 7.6.6 (1756.15) <C2567783-4EAC-6803-522B-D701B95C4DAE> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x91d80000 - 0x91d88ff7  com.apple.DisplayServicesFW 2.3.0 (283) <48D94761-7340-D029-99E3-9BE0262FAF22> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x92088000 - 0x920c8ff3  com.apple.securityinterface 4.0.1 (40418) <26D84A83-F5B9-93CF-71BB-0712698181EE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
      0x92158000 - 0x92177ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x92178000 - 0x921beff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
      0x921bf000 - 0x921c9fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x92226000 - 0x92c79ff7  com.apple.WebCore 6533.21 (6533.21.1) <09CE6602-4DB5-6E93-8593-4E1C57CB202F> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
      0x92d23000 - 0x93512557  com.apple.CoreGraphics 1.545.0 (???) <8A4CB0D9-1001-0F62-4DA4-B8AB3B45E226> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x93513000 - 0x93656fef  com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x93657000 - 0x936effe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x937fd000 - 0x938fffef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x9392c000 - 0x9399bff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <706684C7-AFA0-B036-274A-D02F8961DED5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x9399c000 - 0x93b7efff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x93b7f000 - 0x93bbdff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x93bbe000 - 0x93bbeff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x93c2e000 - 0x93c52ff7  libJPEG.dylib ??? (???) <A50127EB-C202-0436-E62D-41E2E893E436> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x93c7a000 - 0x93c84ffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x93c85000 - 0x93d32fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
      0x93d33000 - 0x93dd0fe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x93dd1000 - 0x94208ff3  com.apple.RawCamera.bundle 3.6.4 (561) <DBA5D7C1-CD82-CE7F-5AE5-A0E4E128236F> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x94211000 - 0x943edffb  libType1Scaler.dylib ??? (???) <494D1BE1-8395-9A53-1224-1CFD4236D40E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libType1Scaler.dylib
      0x943ee000 - 0x943ffff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x94400000 - 0x9443dff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x9443e000 - 0x94485ffb  com.apple.CoreMediaIOServices 134.0 (1160) <4CD78557-3CDA-A4B5-33CB-BBB876B4463D> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x94486000 - 0x944c1feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x944c2000 - 0x944f5ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x944f6000 - 0x944f7ff7  com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x94531000 - 0x94541ff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x94769000 - 0x947fbfe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x947fc000 - 0x94803ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x94804000 - 0x94807ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B84D7376-EE9C-2B7F-04FA-D622E2C10CA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x94808000 - 0x94a06ff3  com.apple.JavaScriptCore 6533.20 (6533.20.20) <C97A479C-FDF9-3F19-2EE0-80288257C477> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x94a41000 - 0x94aafff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x94ab0000 - 0x94ab0ff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x94ab1000 - 0x94ac1ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x94ac2000 - 0x94aceff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
      0x94acf000 - 0x94ad3ff7  libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x94ad4000 - 0x94afeff7  com.apple.shortcut 1.1 (1.1) <B0514FA9-7CAE-AD94-93CA-7B2A2C5F7B8A> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
      0x94b1f000 - 0x94b9ffeb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x94bb4000 - 0x94c70fff  com.apple.ColorSync 4.6.6 (4.6.6) <D00B95AE-2379-CB8E-B18C-FF5B66741C23> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x94c71000 - 0x94d80fe7  com.apple.WebKit 6533.21 (6533.21.1) <4FBCE2F9-84EB-302C-FD1F-DAD2422A219E> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
      0x94d8e000 - 0x94e08fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x94e09000 - 0x94e0cff7  libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x94e0d000 - 0x94e4fff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <29E5ABCF-6D8A-0CE0-B480-C7D240FF8575> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x94f05000 - 0x94fd6fe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
      0x9500c000 - 0x9505dff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x9505e000 - 0x951d9fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x951da000 - 0x9521efe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x9521f000 - 0x9525cff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x9525d000 - 0x95278ff7  libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x952fb000 - 0x9532effb  libTrueTypeScaler.dylib ??? (???) <574C2C51-65EC-7D2A-086D-C9312287DE22> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x9532f000 - 0x95334ff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x95335000 - 0x95342ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x9537b000 - 0x9537bff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x9537c000 - 0x9538aff7  com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x953cc000 - 0x953ccff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x953cd000 - 0x954fbfe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x95512000 - 0x95515fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x9552f000 - 0x95533ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x9564a000 - 0x9566afe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
      0x956b2000 - 0x957eeff7  com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x957ef000 - 0x957efff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x95812000 - 0x958bcfe7  com.apple.CFNetwork 454.11.12 (454.11.12) <BE832CCE-B692-F55F-F5F8-3973649AFEA1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x958bd000 - 0x95cf2ff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x95cff000 - 0x95d35fff  libtidy.A.dylib ??? (???) <0FD72C68-4803-4C5B-3A63-05D7394BFD71> /usr/lib/libtidy.A.dylib
      0x95d36000 - 0x95e10ffb  com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x95e11000 - 0x95f12fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
      0x95f3e000 - 0x95ff5feb  libFontParser.dylib ??? (???) <DDBBB503-5289-2E2B-AD35-F3BA00D00D5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x96004000 - 0x96186fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D375C1CF-C88D-C5F6-3C49-CD429023FBAC> /usr/lib/libicucore.A.dylib
      0x9619a000 - 0x961f7ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x961f8000 - 0x9621afef  com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x96229000 - 0x9623efff  com.apple.ImageCapture 6.0.2 (6.0.2) <E9F4B952-27A1-5BFC-CA8D-DADA055D30E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x9623f000 - 0x96267ff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x96268000 - 0x96272ff7  com.apple.HelpData 2.0.5 (34.1.1) <A9CF754F-B254-5D40-B8B5-F35414DFD875> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
      0x96273000 - 0x962c0feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x962c1000 - 0x965e5fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x965e9000 - 0x965f4ff7  libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x966d7000 - 0x967cbff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <9EC28185-D26F-533F-90C4-FBAA13A15947> /usr/lib/libiconv.2.dylib
      0x967cc000 - 0x96830ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x96831000 - 0x968fcfef  com.apple.CoreServices.OSServices 359 (359) <EC340F74-8192-C9DD-40B3-AE4E519A38D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x968fd000 - 0x96915ff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x96916000 - 0x9696efe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x9696f000 - 0x9724fff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x97291000 - 0x97292ff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x97293000 - 0x9744dfeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C96F11A7-2569-3037-C4C3-0342708FA3CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x9744e000 - 0x9744eff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x9744f000 - 0x974f7ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x974f8000 - 0x9757affb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x9757b000 - 0x9789bff3  com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x9789c000 - 0x979a0fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
      0x979a1000 - 0x979acff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x979ad000 - 0x979ddff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x979de000 - 0x97a5bff7  com.apple.iLifeMediaBrowser 2.5.4 (468.1.1) <3B7F5895-B48D-A2E0-D708-58EC58EB9514> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
      0x97a5c000 - 0x97a95ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
      0x97a96000 - 0x97ab7fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x97ab8000 - 0x97d2bfe7  com.apple.Foundation 6.6.6 (751.53) <C73FDD37-000B-C505-FD8D-80D1C9D17965> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x97d2c000 - 0x97d33ff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x97d6d000 - 0x97e26fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
      0x97e27000 - 0x97f53ffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x97f54000 - 0x97f98ff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x97f99000 - 0x97ff3fe7  com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x97ff4000 - 0x97ff7ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x97ffd000 - 0x98134ff7  com.apple.CoreAUC 6.04.05 (6.04.05) <4A2BEE1A-A74A-746B-EFA6-470CD3354252> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
      0x98137000 - 0x9908afe3  com.apple.QuickTimeComponents.component 7.6.6 (1756.15) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
      0x9953a000 - 0x9957bff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x99590000 - 0x995c1ff7  libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x995c2000 - 0x995c6ff7  libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x995c7000 - 0x9960aff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x9960b000 - 0x99675fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x99676000 - 0x998dbfeb  com.apple.security 6.1.2 (55002) <7F00A51B-F22A-0EBC-A321-923472D686BD> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x99918000 - 0x99991ff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x99a77000 - 0x99abaff7  libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x99abb000 - 0x99ae1ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0xb0000000 - 0xb000fff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <24B39C2F-79B0-BDE3-C6D0-1F0E943070C7> /Applications/Adobe Flash CS5/Adobe Flash CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xbb100000 - 0xbb103fe7  libLatinSuppConverter.dylib 49.0.0 (compatibility 1.0.0) <80CA35C5-AFBF-DD2D-B47B-9CE773B9CAEF> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
      Model: MacBookPro5,3, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 2.8 GHz, 4 GB, SMC 1.48f2
      Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe, 512 MB
      Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
      Memory Module: global_name
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.10.131.36.9)
      Bluetooth: Version 2.4.0f1, 2 service, 19 devices, 1 incoming serial ports
      Network Service: Ethernet, Ethernet, en0
      Serial ATA Device: Hitachi HTS545032B9SA02, 298.09 GB
      Serial ATA Device: MATSHITADVD-R   UJ-868
      USB Device: Generic USB2.0 Device, 0x090c  (Silicon Motion, Inc. - Taiwan), 0x6200, 0x24100000
      USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8507, 0x24400000
      USB Device: Internal Memory Card Reader, 0x05ac  (Apple Inc.), 0x8403, 0x26500000
      USB Device: Apple Internal Keyboard / Trackpad, 0x05ac  (Apple Inc.), 0x0236, 0x04600000
      USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x04500000
      USB Device: USB Optical Mouse, 0x046d  (Logitech Inc.), 0xc018, 0x06200000
      USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x06100000
      USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8213, 0x06110000
