2 Replies Latest reply on May 26, 2011 5:50 AM by roestigraben
    cannot pass color info
    roestigraben
      Hi all,
      I fairly new in Flex, so bear with me.
      I created a component based on BorderContainer and wanted to pass various info from the parent application into this component.
      See below code where I took out pretty much everything that has nothing to do with my problem.
      I  want to place a bullet on the x axis and pass the x coordinates (HEDcompleteMAT20requestX) and the color of the bullet (HEDBC).
      While the x coordinate work perfectly fine, I cannot get the color to work. It stays stubbornly black (probably default value).
      many thanks
      Peter
      <s:BorderContainer xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx" backgroundColor="#EFEFEF"
         horizontalCenter="0" verticalCenter="0">
      <fx:Script>
      <![CDATA[
      import mx.events.FlexEvent;
                      [Bindable]
      public var HEDcompleteMAT20requestX:Number = 0;
      [Bindable]
      public var HEDBC:String = "green";
      </fx:Script>
      <s:Ellipse width="14" height="14" x="{HEDcompleteMAT20requestX}" y="20">
      <s:fill>
      <s:SolidColor color="{HEDBC}" />
      </s:fill>
      <s:filters>
      <s:BevelFilter/>
      </s:filters>
      </s:Ellipse>
      </s:BorderContainer>
        • 1. Re: cannot pass color info
          Filmzaddict
          inside your components script section define a private variable, then define a public property for it like this:
          private var _someColor:uint;
          public function set SomeColor(value:uint):void
          {     _someColor = value;     }
          //dont need the get part of the property
          Inside your component you can use _someColor as you wish, but on the outside you will be able to write:
          <MyComponentName SomeColor="0xff0000" /> for example.
          About color type you are using, you should probably pass them as hex values representing unsigned integers!
          Hope this is of some help!
          • 2. Re: cannot pass color info
            roestigraben Level 1
            most helpful, thanks again
