0 Replies Latest reply on May 25, 2011 12:06 AM by JohanVelthuis
    Bug and workaround: not showing custom contextmenu in flex 4.5 sdk
    JohanVelthuis Level 1
      Dear all,
      I ran into a bug in flex 4.5 that wasn't there in 4.1.
      It took me about an hour to find out the problem, i hope this helps some people.
      The problem seens to be with binding a contextmenu:
      If one creates a bindable contextmenu en use that on for instance a datagrid, it shows in 4.1, but not in 4.5:
      <mx:DataGrid contextmenu="{myContextMenu}" />
      But if one uses: myGrid.contextmenu = myCustomContextMenu; after myCustomContextMenu is created, it works in both SDK's.
      I included a working/non-working example:
      testContextMenu.mxml:
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:comp="comp.*" creationComplete="application1_creationCompleteHandler(event)">
          <fx:Script>
              <![CDATA[
                  import mx.events.FlexEvent;
                  [Bindable]
                  private var myContextMenu:ContextMenu;
                  protected function application1_creationCompleteHandler(event:FlexEvent):void
                      myContextMenu = new ContextMenu();
                      var myContextMenuItem:ContextMenuItem = new ContextMenuItem("Test contextmenu");
                      myContextMenu.hideBuiltInItems();
                      myContextMenu.customItems = [myContextMenuItem];
                      //this works in Flex 4.5 SDK:
                      //myGrid.contextMenu = myContextMenu;//uncomment this line to check it out
          </fx:Script>
          <!--Line below works in Flex 4.1 SDK, but in Flex 4.5 there probably is a problem with the binding, because myContextMenu is not shown.-->
          <comp:sampleDataGrid id="myGrid" contextMenu="{myContextMenu}" />
      </s:Application>
      sampleDataGrid.mxml:
      <mx:DataGrid xmlns:fx="http://ns.adobe.com/mxml/2009"
                   creationComplete="datagrid1_creationCompleteHandler(event)"
                   dataProvider="{ac}">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable]
                  private var ac:ArrayCollection = new ArrayCollection();
                  protected function datagrid1_creationCompleteHandler(event:FlexEvent):void
                      var obj:Object;
                      obj = new Object();
                      obj.name = "John";
                      obj.number = 1;
                      ac.addItem(obj);
                      obj = new Object();
                      obj.name = "Foo";
                      obj.number = 2;
                      ac.addItem(obj);
          </fx:Script>
      </mx:DataGrid>
