2 Replies Latest reply on May 25, 2011 8:02 AM by gkaiseril
    Script for calculations using checkboxes in PDF form
    isabeldelgado
      I have 7 checkboxes, at least one must be checked, but the user may select all. Each one has a value of 800, therefore selecting all seven would give a total of (800 + 800 + 800 + 800 + 800 + 800 + 800). Selecting only two: (800 + 800), etc.
      However, the last checkbox is a 50% discount for students.
      I'd like the total to have this formula:
      (CheckBox1 + CheckBox2 + CheckBox3 + CheckBox4 + CheckBox5 + CheckBox6 + CheckBox7) = x
      If CheckBox8 is selected, then x/2.
      I've done (CheckBox1 + CheckBox2 + CheckBox3 + CheckBox4 + CheckBox5 + CheckBox6 + CheckBox7) / CheckBox8
      but in this way, I only get a value if the CheckBox8 discount is selected. Not everyone will be a student.
      Excel, Access, no problem, but I'm new to javascript and pdf forms. Any suggestions?
      Isabel
        • 1. Re: Script for calculations using checkboxes in PDF form
          isabeldelgado Level 1
          I think I figured it out:
          I did a simple add into a text field "Modulos" (CheckBox1 + CheckBox2 + CheckBox3 + CheckBox4 + CheckBox5 + CheckBox6 + CheckBox7)
          I set the value of CheckBox8 (which determined whether the person is a student or not) to 1.
          In the Total text field:
          if (this.getField("CheckBox8").value=="1") {event.value = this.getField("Modulos").value * 0.5;} else event.value = this.getField("Modulos").value;
          • 2. Re: Script for calculations using check boxes in PDF form
            Two things about Acrobat JavaScirpt and forms you should be aware of:
            1. Check boxes and radio boxes have a string value of "Off" when there is no selection is made for the field or a field within an exclusionary group of fields, fields with the same name but different export values.
            2. One can not divide by zero and expect a reasonable answer. You will get a string returned with a value of "NaN' (Not a Number), "Infinity", or "-Infinity". Those values maybe number types but the numeric field type can not display them and reports a format error. You can check this by setting the field format to 'None'.
