1 Reply Latest reply on May 25, 2011 8:28 AM by darrellberryRSI
    Flex Builder 4 Export Release Build fails on OSX
    darrellberryRSI
      Flex Builder 4, SDK 4.1.0.16076
      When I choose Project->Export Release Build, or Export Release Build from the Export context menu, nothing happens on teh interface, but I see the following error in the log. Any thoughts on solution or workaround?
      D
      !ENTRY org.eclipse.ui 4 0 2011-05-25 14:54:44.886
      !MESSAGE Unhandled event loop exception
      !STACK 0
      java.lang.NullPointerException
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.getDefaultOutputFolderPath(ExportReleaseVersionProjectAndLocationPage.java:312)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createLocationControls(ExportReleaseVersionProjectAndLocationPage.java:297)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionProjectAndLocati onPage.createControl(ExportReleaseVersionProjectAndLocationPage.java:501)
      at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:170)
      at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard.createPag eControls(ExportReleaseVersionWizard.java:310)
      at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:734)
      at org.eclipse.jface.wizard.WizardDialog.createContents(WizardDialog.java:606)
      at org.eclipse.jface.window.Window.create(Window.java:431)
      at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
      at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction$1.run(Export ReleaseVersionAction.java:93)
      at com.adobe.flexbuilder.exportimport.releaseversion.ExportReleaseVersionAction.run(ExportRe leaseVersionAction.java:103)
      at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
      at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
      at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
      at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
      at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1669)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1693)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1678)
      at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1421)
      at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3657)
      at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3240)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
      at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
      at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
      at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
