0 Replies Latest reply on May 27, 2011 2:27 AM by SPGAnne
    why does my pre-loader flicker
    SPGAnne Level 1
      I just installed FlashPlayer 10.3.181 (yeah...I know I've been down level for a while).  The custom preloader I built for my Flex 3 ages and ages ago and has worked forever now flickers and flashes and disappears from the screen.  Why would that be?  How can I make my preloader work properly again?
      HELP!!!!!  Here's my code:
      public class ProgressBar extends Loader{
      Bindable]
      private var logoClass:Class; //must be set when constructed
      private var logoBitmap:Bitmap;
      private var _ready:Boolean;
      private var _progress:Number;
      private var m_BitmapData:BitmapData;
      private static var ProgressWidth:int = 150; // Progress bar width
      private static var LeftMargin:int = 1; // Left Margin
      private static var RightMargin:int = 2; // Right Margin
      private static var Spacing:int = 10; // Spacing between logo and progress bar
      private static var TopMargin:int = 1; // Top Margin
      private static var BottomMargin:int = 1; // Bottom Margin
      private static var ProgressHeight:int = 15; // Progress bar height
      private static var ProgressBarBackground:uint = 0xFFFFFF;
      private static var progressBarOuterBorder:uint = 0xc4e1ff;
      private static var ProgressBarColor:uint = 0x014e98;
      private static var ProgressBarInnerColor:uint = 0xFFFFFF;
      public function ProgressBar(logoClass:Class):void{
      super();
      this.logoClass = logoClass;
      _progress = 0;
      if(logoClass){
      logoBitmap =
      new logoClass as Bitmap;
      public function refreshProgressBar():void{
      m_BitmapData = drawProgress();
      // Create the bitmapdata object
      var encoder:PNGEncoder = new PNGEncoder();
      var byteArray:ByteArray = encoder.encode(m_BitmapData); // Encode the bitmapdata to a bytearray
      this.loadBytes(byteArray); // Draw the bitmap on the loader object
      public function getWidth():Number{
      var w:Number = LeftMargin + ProgressWidth + RightMargin;
      if(logoBitmap) w += logoBitmap.width + Spacing;
      return w;
      public function getHeight():Number{
      var h:Number = TopMargin + BottomMargin;
      if(logoBitmap) h += logoBitmap.height;
      h = Math.max(h,20);
      return h;
      public function getBarX():Number{
      var x:Number = LeftMargin;
      if(logoBitmap) x += logoBitmap.width + Spacing;
      return x;
      private function drawProgress():BitmapData{
      // Create the bitmap class object
      var bitmapData: BitmapData = new BitmapData(getWidth(), getHeight(), true, 0);
      // Draw the Progress Bar
      var sprite:Sprite = new Sprite();
      var graph:Graphics = sprite.graphics;
      // Draw the progress bar background
      graph.beginFill(ProgressBarBackground);
      graph.lineStyle(1, progressBarOuterBorder, 1,
      true);
      var containerWidth: Number = ProgressWidth;
      var px:int = getWidth() - RightMargin - ProgressWidth;
      var py:int = (getHeight() - ProgressHeight) / 2;
      graph.drawRoundRect(px, py, containerWidth, ProgressHeight, 6);
      containerWidth -= 4;
      var progressWidth: Number = containerWidth * _progress / 100;
      graph.beginFill(ProgressBarColor);
      graph.lineStyle(1, ProgressBarInnerColor, 1,
      true);
      graph.drawRoundRect(px + 2, py + 2, progressWidth, ProgressHeight - 4, 6);
      bitmapData.draw(sprite);
      //Draw the Logo
      if(logoBitmap){
      bitmapData.draw(logoBitmap.bitmapData,
      null, null, null, null, true);
      return bitmapData;
      public function set ready(value:Boolean): void{
      _ready = value;
      this.visible = !value;
      public function get ready():Boolean{
      return _ready;
      public function set progress(value:Number): void{
      _progress = value;
      public
      function get progress():Number{
      return _progress;
