7 Replies Latest reply on Jul 14, 2011 1:43 PM by insuractive
    XPath question
    nikos101 Level 2
           I know how to do this using for loops but was wondering if it was possible with Xpath.
      My xml isl like that:
      <ROOT>
          <Batch BatchID="19" >
              <Order Swift="AUD"  />
              <Order Swift="USD"  />
         </Batch>
          <Batch BatchID="22" ">
           </Batch>
      </ROOT>
      I want to return an array like that:
        <Order Swift="AUD"  BatchID="19" />
         <Order Swift="USD"  BatchID="19" />
         <Order Swift="AUD"  BatchID="22"  />
      thanks gurus
        • 1. Re: XPath question
          Adam Cameron. Level 5
          Yep.  What have you done by way of finding out how to do it?
          For starters, there are some easy to follow tutorials here:
          http://www.zvon.org/comp/r/tut-XPath_1.html
          Adam
          • 2. Re: XPath question
            nikos101 Level 2
            thanks,Ive doen research, this is my working code, works but is clunky
            <cfscript>
                getData(xmlFeed);
                function GetData(xml)
                    allOrders = XmlSearch(xmlFeed, "ROOT/Batch");
                    var i = 0;
                    for(i = 1; i <= arraylen(allOrders); i = i + 1)
                        var children = allOrders[i].XmlChildren;
                        for(var j = 1; j <= arraylen(children); j = j + 1)
                            structInsert(allOrders[i].XmlChildren[j].XmlAttributes,"BatchID",allOrders[i].XmlAttribut es["BatchID"]);
                                    writeDump(allOrders);
            </cfscript>
            • 3. Re: XPath question
              nikos101 Level 2
              here is my code ,fixed
              <cfhttp method="get" url="http:/52.xml"
                      result="xmlFeed"/>
              <cfset xmlFeed = xmlParse(xmlFeed.FileContent)>
              <cfscript>
                  getData(xmlFeed);
                  var final = arrayNew(1);
                              structInsert(allOrders[i].XmlChildren[j].XmlAttributes, "BatchID",  allOrders[i].XmlAttributes["BatchID"]);
                                        arrayAppend(final,allOrders[i].XmlChildren[j]);
                      writeDump(final );
              </cfscript>
              • 4. Re: XPath question
                You can simplify that a bit. You're after the orders but you're only xpathing as far as the batch. You can path it all the way to the orders: /ROOT/batch/order. That saves some horsing around.
                Also don't forget to always VAR •all• your variables inside functions. Not just some of them.
                Adam
                • 5. Re: XPath question
                  nikos101 Level 2
                  thanks
                  I know about
                  /ROOT/batch/order
                  but that doesn't get the outer Batch ID in each of the corresponding children, I think my loops are the only way for that?
                  • 6. Re: XPath question
                    Oops... forgot to reply.  Yeah, you're right.  Sorry: didn't notice you needed stuff from the parent nodes too.
                    Adam
                    • 7. Re: XPath question
                      insuractive Level 3
                      Have you considered applying an XSL transformation instead of trying to parse/write the data in CF?
