3 Replies Latest reply on May 28, 2011 10:07 AM by j-friedrich
    Time stretching...
    j-friedrich
      Hi guys,
           I am a little new to this, so here goes....
      I have a sequence with different transitions and whatnot.  Time stretching just slows / extends everything.  I want to keep the pace of the sequence, but, make everything run longer?
      Suggestions?
      As always, thanks!
      Jason
        • 1. Re: Time stretching...
          j-friedrich Level 1
          BTW, time-remapping is greyed out?  Dunno?
          • 2. Re: Time stretching...
            I'm not following you. If you move layer 1 from position a to position b in 10 frames and a to b is 100 pixels then a to b is moving at a speed of 10 pixels per frame. If you change the time from a to b to 20 frames then the movement from a to b is now 5 pixels per frame. The speed is cut in half.
            If, on the other hand, you're rotating layer 1 at 10º per frame and it's rotating for 10 frames but you want to keep a rotating at 10º per second for 20 frames then you simply move the keyframe at frame 10 to frame 20 and add 100º to the value.
            If you have a series of keyframes that you want to keep uniformly spaced but change the duration then select al the keyframes in the line, then hold down the Alt or Option (win or mac) key and click and drag on the last keyframe.
            A better description of your project would help solve your problem.
            One last thing, if time remapping is grayed out (unavailable) then that means the layer has no native motion (it's not video). You can fix this by pre-composint, moving all attributes, then applying time remapping to the layer. Time remapping will let you change the speed of everything on the layer uniformly.
            • 3. Re: Time stretching...
              j-friedrich Level 1
              Hi Rick,
                   I got it.  Sorry.  I pre-composed the layers, then used the graph editor to put in a 'keyframe hold' to extend the sequence and then another linear keyframe to move on to the next section.  That way, the animation part stays the same and I am freeze-framing the last part to 'extend it' and then resume with a linear keyframe.  Correct?
              It looks ok now.
              Thanks.
              Jason
