2 Replies Latest reply on May 29, 2011 11:24 AM by vze26m98
    ExtendScript: Reading vs. writing InDesign references
    vze26m98
      Hi all-
      Not hugely versed in Javascript as well as InDesign, so perhaps this is a language rather than application question. I have some code that looks like this:
      var theSelection = app.documents.firstItem().selection;
      var theTextFrames = theSelection[0].parentStory.texts;
      var numTextFramesSelected = theSelection.length;
      var documentFilePath = app.activeDocument.filePath;
      function ROW(i){
        return theTextFrames.item(0).associatedXMLElements;
      function DATA(i, COL){
        return ROW(i)[COL].xmlElements.item(0).contents;
      function setDATA(i, COL, boxContents){
        ROW(i).item(COL).xmlElements.item(0).contents = boxContents;
      So, the notion is that the element references that are used in the functions are built from variables that contain portions of the element reference. The portions of the code that READ the elements seems to work OK, but the portions that WRITE to the elements inevitably fail. Any thoughts on what I'm doing wrong here?
      A further question: I know I can refer to my InDesign elements like so:
      app.documents.firstItem().selection[0].parentStory.texts[0].associatedXMLElements
      but my past association with Applescript always encouraged me to get my references as few times as possible, I guess because of the cost of inter-application communication in Applescript's case.
      But with ExtendScript, is there a performance penalty in getting these references each time you run through a loop?
      Thanks, Charles
        • 1. Re: ExtendScript: Reading vs. writing InDesign references
          John Hawkinson Level 5
          Hello.
          "Inevitably fail" is awful vague. Just what happens that goes wrong?
          app.documents[0] is a lot more compact than .firstItem(), btw.
          app.documents.firstItem().selection[0].parentStory.texts[0].associated XMLElements
          Yes there is. But I wouldn't worry about it unless you were doing 100s of iterations rather than 10s. But one can use
          var myArray = ....associatedXMLElements.everyItem().getElements();
          and then loop for (i=0; i< myArray.length; i++)
          • 2. Re: ExtendScript: Reading vs. writing InDesign references
            vze26m98 Level 1
            [The cleanup mentioned below, plus correcting an incorrect parameter value >blush< fixed my issue. Thanks again!]
            Hi-
            Thanks for your interest.
            Re: the efficiency of iterations, I could possibly have a thousand, but I have to believe it will go faster than Applescript. The pointer to getElements() is very helpful.
            As far as my main question goes, here's some cleaned up code. (Between a review of what I had and your suggestions, it's much simplified:)
              return app.documents[0].selection[i].associatedXMLElement.xmlElements[COL].contents;
              app.documents[0].selection[i].associatedXMLElement.xmlElements[COL].contents = boxContents;
            When I run this, I'm able to READ the DATA through the first function, but WRITING the DATA through the second function gives me this:
            So perhaps the typeof "contents" is an object and not a string, so ExtendScript does the conversion on read, but not on write?
            Anyway, any insight is greatly appreciated!
            Best, Charles
            Message was edited by: vze26m98
