3 Replies Latest reply on May 30, 2011 7:51 AM by Jim_Simon
    still unclear on RAID
    kirm99
      I'll be shooting with a Sony EX1R - sometimes with a Nanoflash @ 100mbps - and outputing same. Maybe converting to NeoHD editing format in CS5 (would that be an advantage?)
      1) Pretty sure I'll need a RAID array - but what configuration? I was leaning toward RAID 5, but then saw that Harm called it a non-video array (?)
      2) and will it work with most new mother boards? or does it require a hardware card?
      3) also, interior or exterior RAID drives? is heat a problem?
      4) Plus I keep reading about Throughput - but not sure how to calculate my needs. I found some crazy formulas online - but is there another way?
      5) and would I include the scratch area inside the RAID array - or have a seperate HDD - and does that need to be able to handle a certain speed of data???
      6) finally, what color should we paint the bathroom? (ha - just kidding)
      this seems to be the last hurdle I need to jump before buying a new machine.  Thanks for your advice!
        • 1. Re: still unclear on RAID
          Harm Millaard Level 7
          Raid 5 is better in high I/O situations, whereas Raid 3 is better in high transfer rates.  As long as the raid is not degraded, the differences are small and a raid 5 controller is usually less expensive than an Areca controller, which is needed for raid 3. But when one looses a single disk, the rebuilding of the array takes much longer on a raid 5 than on a raid 3, unless the parity disk on a raid3 is the one to go. If a data disk dies, a raid 5 requires reading and writing to all the disks in the array, a raid 3 needs to read from all disks but only write to a single disk. The rebuild overhead is much larger with raid 5.
          Yes, but with a severe performance penalty, so effectively you need a hardware card for parity raids.
          Interior is much easier and heat is no problem. I have 17 disks internally and never had any problem with heat, despite overclocking.
          If all you do is single track editing, throughput is irrelevant. If you often have large numbers of tracks using hi-res material, throughput requirements will sky-rocket. There is no simple answer, but generally, the higher the better. Throughput is often the bottleneck in modern systems.
          Look here: http://forums.adobe.com/thread/662972
          • 2. Re: still unclear on RAID
            brorob
            Thanks for the info.
            I'm doing a lot of layering and effects, so you think I'd be okay with a hardware-card controlled, internal RAID 5 (4 disks)?
            and then a seperate HDD for a scratch disk? I guess I'm not sure what I'd need to play back 100MBPS HD video? would that play from any HDD?
            thanks again!
            • 3. Re: still unclear on RAID
              Jim_Simon Level 8
              You may not.  100Mbps is also the data rate of DVCPRO HD.  I've not had any issues with this working off a single modern drive.
              If you need 10 layers at the same time, it might be an issue.  But for many editing purposes, a single drive might work just fine.
