3 Replies Latest reply on May 30, 2011 3:23 PM by MECS
    Handler not defined
    MECS Level 1
      I searched the thread by that name, but didn't find an issue that was close enough to mine to solve my problem.  After a couple of years, I am back on a project that uses the buddy api xtra.  I am rusty on its implementation, so I may be doing something glaringly obvious that is causing the problem.
      The first thing I want the program to do is take a peek into the registry and see if a Key is there called PVUD/2d..  If it doesn't exist, then write it and set its value to 0.
      If it does exist, then leave its value alone and jump to frame "compare".
      Can you enlighten me on what I'm doing wrong?
      Thanks.
      Here is the code:
      on exitFrame me
        global regcheck
        set regcheck = baReadRegNumber("PVUD/2d","FstD","HKEY_CLASSES_ROOT")
        if regcheck = empty then
          baWriteRegNumber("PVUD/2d","FstD",0,"HKEY_CLASSES_ROOT")
        else
          go frame "start"
        end if
      end
      Here is the result:
      Director
      Script error: Handler not defined
      #baReadRegNumber
        • 1. Re: Handler not defined
          Mike Blaustein Level 4
          If you aer getting Handler Not Defined, then it is likely that you do not have BuddyAPI installed.  The second thing is that you are using it wrong.  Check the docs for the correct syntax:
          http://www.mods.com.au/budapi_docs/baReadRegNumber.htm
          There should be 4 arguments, and you are only supplying 3.
          Also, the reseult will never be empty, since the command will return a number all the time (the argument you are missing is the one that defines the default return if the key is missing)
          • 2. Re: Handler not defined
            MECS Level 1
            Ok, Mike.  Thanks.  I’ll check that out to see what I missed.
            I appreciate your quick response.
            Sent: Sunday, May 29, 2011 1:36 PM
            To: Dewey Parker
            Subject: Re: Handler not defined
            • 3. Re: Handler not defined
              MECS Level 1
              Both responses were halpful in allowing me to properly install my Xtra, and correct my syntax.
              Much appreciated.
              Dewey
