2 Replies Latest reply on May 30, 2011 3:24 AM by ThomasJames_T
    Flashbuilder 4.5 Alert.show error
    ThomasJames_T Level 1
      My shutdown method looks like
          private function onShutDown(event:Event):void {
                  event.preventDefault();
                  Alert.show("Do you REALLY want to close this application?", "Wait! Don't go!", 3, null, onConfirmation);
      And is valid but throws :
      [SWF] AirPureAS.swf - 985,029 bytes after decompression
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at mx.controls::Alert$/show()[E:\dev\hero_private\frameworks\projects\mx\src\mx\controls\Ale rt.as:566]
          at AirPureAS/onShutDown()[C:\Users\Public\Documents\workspace\study\AirPureAS\src\AirPureAS. as:64]
      Am I missing something. I have this setup so that the Flex project runs from a default .as class rather then default mxml application class.
      And it works fine. As long as I leave Alert.show alone...
      My hair is gone, my tea is cold, heeeeeelp!
      Thanks on beforehand
      Thomas
        • 1. Re: Flashbuilder 4.5 Alert.show error
          blazejewicz Level 4
          Hi Thomas,
          there is "wired" dependency to Flex SDK based content (that is "application" not "sprite") in Alert - so it fails when it tries to configure itself to show on screen (as there is no FlexGlobals.topLevelApplication.systemManager and this line is not coded safely - so it fails with runtime error). This is basically what your error means (just click on alert to get to source code and check 566 line of code). I assume you're using pure AS based movie in your project (extending flash.display.Sprite).
          hth,
          regards,
          peter
          • 2. Re: Flashbuilder 4.5 Alert.show error
            Yes suspected last night that must be it after starting at it in debugger.
            I am devicing my own alert box as a result of that, finely designed!
            Thomas
