0 Replies Latest reply on May 30, 2011 2:14 AM by Dimdidim
    Unable to create SOM error when opening an odbc connection
    Dimdidim
      Dear all,
      currently I'm having a huge problem where I wasn't able to find a solution.
      This question already has been asked before, but unfortunately not answered (at least I only found the questions and no answers, yet).
      When I create this document with LCD 7 everything is working well!! So imho there must be a way to fix this in LCD 8, too.
      I'm using:
           LiveCycle Designer ES 8.2.1
           Acrobat 9 pro
      Scenario:
           Datasource1 (called excelSrc):
                ODBC connection (out of an Excel sheet), delayed open activated
                Element: excelName
          Datasource2
                xsd connection
                Structure: <xsdSrc>
                                    <xsdName></xsdName>
                               </xsdSrc>
      First I added both data connections and enabled 'delayed open' for the ODBC source.
      There's no difference whether I use a DSN or a direct connection to the ODBC source.
      After opening the odbc connectino the structure in $record should be as follows:
           xsdSrc.xsdName
           xsdSrc.excelSrc.excelName
      But I always get the error:
      'Unable to create SOM element ($record.excelSrc.excelName)'.
      What I did:
          var oDB = xfa.sourceSet.excelSrc.clone(1);
          xfa.sourceSet.excelSrc.open();  <-- here the error occurs
      When I remove the xsd source this code is working as intended.
      As I wrote above the same code is working with both data sources in the previous version of the LCD.
      I would be very glad, if somebody has a hint to solve this issue, otherwise I have to go back to LCD 7 (what I would like to avoid ...)
      Best regards,
      Dimdi
