• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Import PPT slides in ONE Captivate slide
New Here ,
May 30, 2011 May 30, 2011
Hi there.
How is possible import slides from powerpint into captivate in one unique slide?
When I import more slides, captivate create one slide each ppt slide.....
thanks.
TOPICS
Import export
Views
526
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Can you describe more of what you are trying to accomplish - do you just
want the slides to run through without stopping? Why do you want all the ppt
slides on a single Cp slide?
--Allen
Votes
Translate
Translate
Report
Report
New Here ,
Hi Allen, Because I want to move the slides in one single timeline, add effects, a background... and then export it in a single swf file.
thanks
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Sounds like you want something similar to what Techsmith Camtasia provides.
If so, the way you do this is to configure your PowerPoint to play in a window. Then use Captivate's Full Motion Recording feature to surround the playback area and record the slide show as a full motion recording.
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
Adobe Certified Captivate Training
SorcerStone Blog
Captivate eBooks
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
Kk - the only way I can think to do it easily is to use the export to fla
feature in eLS. (this may be there in Cp as well, don't recall off hand.)
Make sure backgrounds are checked. Ignore the fla that is generated, just
find the folder with all the resources. You should find a set of swfs called
'mypresentation_slide_n.swf - where mypresentation = the name of your
original slide deck. So steps are as follows.
1. create new project from ppt in cp
2. export project to fla
3. find the special slide swfs in the resulting published fla editable
project folder.
Now you can import the swfs (which are in effect your original ppt slides as
many as you like onto a traditional slide and lay them out however you like.
Hope that helps,
--Allen
Votes
Translate
Translate
Report
Report
Resources
Help resources
