3 Replies Latest reply on May 31, 2011 1:05 PM by MT.Freelance
    Help creating an index in "book"
    m.r.hunter
      I'm having a lot of difficulty getting started on an index of terms for all documents in a book. We usually produce a book as a single document, but now using "book" feature. Adobe help not doing it for me.
        • 1. Re: Help creating an index in "book"
          M Blackburn Level 3
          If you've been making indexes already you probably know most of what's in this tutorial by Michael Murphy, but the tutorial does work with the book feature.
          http://www.theindesigner.com/blog/episode-36-long-documents-part-4-indexing-video
          Maybe the thing to note is that you need to have all the documents open since the index panel only displays references for open documents.
          • 2. Re: Help creating an index in "book"
            m.r.hunter Level 1
            I hadn't considered having all the docs open - I'll check out the tutorial. Thank you.
            • 3. Re: Help creating an index in "book"
              MT.Freelance Level 4
              To create a TOC that spans all chapters of a book, you need to:
              • Define Paragraph Styles that apply to the Book Level TOC
              • Ensure those paragraph styles are synced to all documents
              • USE those paragraph styles consistently for your TOC to recognize
              • Define a TOC style that includes those Paragraph styles
              • Enable the "Include Book Documents" option in the TOC style
              It should be that simple.
              The screenshot below shows a TOC example from a Book that I worked with multiple TOC (book level and chapter level).
              TOC Main is the book level TOC
              The other TOC styles were used on the chapter level (differences in the formatting of the chapters resulted in multiple chapter level TOC styles unfortunately, but it worked).
              ChapTOC is the TOC 'chapter'
              You should not need to have the individual chapters open in order to update your TOC. If, however, your styles are not assigned properly, then you will not be able to generate the TOC.
              HTH
              -mt
              EDIT:  OOOPS!
              I saw Index and Parsed TOC.
              Sorry, no help here!!!
              Message was edited by: MT.Freelance
