1. Re: Opening another timeline crashes Premiere
Bill Hunt May 30, 2011 11:43 AM (in response to funkbomb)What platform are you running PrPro CS 5.5 on?
2. Re: Opening another timeline crashes Premiere
funkbomb May 30, 2011 11:59 AM (in response to Bill Hunt)OS X 10.6.7
3. Re: Opening another timeline crashes Premiere
funkbomb May 30, 2011 9:03 PM (in response to funkbomb)Forget it. I'm going back to CS5. Clearly 5.5 is not ready for primetime.
4. Re: Opening another timeline crashes Premiere
John T Smith May 30, 2011 9:17 PM (in response to funkbomb) -
5. Re: Opening another timeline crashes Premiere
dkitsov May 31, 2011 9:29 AM (in response to funkbomb)Just in case you are using a cineform codec, there is an issue currently with multiple sequences in PPro and a cineform codec. I had a similar issue that was fixed by changing sequence settings so that they are not handled by cineform RT engine.
6. Re: Opening another timeline crashes Premiere
funkbomb May 31, 2011 12:28 PM (in response to funkbomb)You are right, it's Cineform's new Neo version. It's happening in CS5 as well.
7. Re: Opening another timeline crashes Premiere
dkitsov May 31, 2011 1:05 PM (in response to funkbomb)Easy fix. Create a new sequence and choose some other preset (not a cineform one (as a matter of fact I have removed all of the cineform presets from my Adobe presees folders, as well as CFRT plugin from plugins directory))
Then make this settings:
NB! Pay special attention to Video Previews Section of the settings tab.
After that copy all of your clips from your existing cineform preset sequences into a new sequence you have created, you should have no more crushes and no more issues with titles. Apparently there is a bug in SDK and cineform people are aware and working on it.
All of your first light settings will work just fine too. As a matter of fact you will be surprized how much more responsive your PPro will become and as a matter of fact Mercury Playback and rendering of the effects will be restored. As of now, when using cineform real time playback plug in inside the PPro, Mercury Playback and Effects become broken
8. Re: Opening another timeline crashes Premiere
Jeff Bellune May 31, 2011 12:56 PM (in response to funkbomb)[Off-topic posts deleted]
