2 Replies Latest reply on May 31, 2011 10:10 AM by PierreSolutions
    DateTimeFormatter.format() and date stored as string
    PierreSolutions Level 2
      Greetings,
      I need to display some data in a spark data grid and would like to format a date from that data with a labelFunction calling a DateTimeFormatter's format function.
      The date is stored in my ArrayCollection in the following format '2004-05-03 01:03:52.0'
      my formatter is as follows
      <s:DateTimeFormatter id="dateFormatter" dateTimePattern="YYYY-MM-DD" />
      I would like my label function to return something like
      return "Date: " + dateFormatter.format( item[column.dataField]); // where the item[column.dataField] = "2004-05-03 01:03:52.0"
      The date is coming up blank. I'm thinking I need to convert the string "2004-05-03 01:03:52.0" to a Date object first, then pass that into the format() call.
      Is that the way to go? If so, what's the best way to handle that?
