5 Replies Latest reply on Jun 15, 2011 9:53 AM by swarren5
    Need assistance with tweaking a JavaScript for a form...
    swarren5
      In the script below, designed to lock all fields of a form; I need to tweak it so that if a specific option (Enterprise), is chosen from a DropDownList, every field in the form except TextField16 is automatically locked for editing, along with the Button functions that are already coded as exceptions in this script.  I am not a programmer, and the kind assistance from a member of this forum who gave me this script, will not be available for the next 6 weeks while he is on vacation.
      Anyone?
      __________________________________________________________________________________________ ________________________________________
      form1.#variables[0].myScriptObject - (JavaScript, client)
      Function: LockAllFields
      Description: This function will lock all fields.
      IN: The parent subform. It could also be an element that contains subform like form1
      OUT : nothing
      function
      LockAllFields(myParentObject){
      var allChildElements;
      var intNumElements;
      var currentElement;
      var j;
      var temp;
      //Get all the child nodes of the parent element
      allChildElements
      = myParentObject.nodes;
      //Total number of element in the object
      intNumElements
      = allChildElements.length;
      //Loop through all the child elements
      for(j=0; j< intNumElements;j++){
      currentElement
      = allChildElements.item(j);
      //If the element is another subform we'll recusively call the function again
      if(allChildElements.item(j).className == "subform"){
      LockAllFields(currentElement);
      //If the objects are fields and they are set to mandatory (validate.nullTest) then we will set the border.fill.color - dependant on object type
      else if(currentElement.className == "field"){
      //CHeck to see if the field is a button - do not lock buttons
      temp
      = currentElement.name;
      if (temp.substring(0,6) != "Button"){
      currentElement.access
      = "readOnly";
      //Check for exclusion groups - Radio Buttons
      else if(currentElement.className == "exclGroup"){
      for(k=0; k< currentElement.nodes.length;k++){
      if(currentElement.nodes.item(k).className == "field"){
      //set the color for the radio buttons individually
      = "readOnly";
      //end function
