2 Replies Latest reply on May 31, 2011 12:04 PM by maphiom
    Create graphics frame with an "X"
    maphiom Level 1
      Hi guys,
      I wrote a script to quickly split a selected frame into two, with a 2.5 mm gutter in the middle. But the documents I use it in usually contain a lot of different frames, so I would like the frames I create to look like graphics frames, with two diagonal lines. Do you know of a way to do that?
      My script resizes the existing frame and creates another one through rectangles.add. It works fine (except for the missing diagonal lines) but there might be a better way.
      Thanks a lot!
      Matteo
      myDoc = app.activeDocument;
      var myRectangle = app.selection[0];
      var myBounds = myRectangle.geometricBounds;
      var X1 = myBounds[1];
      var Y1 = myBounds[0];
      var X2 = myBounds[3];
      var Y2 = myBounds[2];
      RX1 = X1;
      RX2 = X1+(X2-X1-2.5)/2;
      RY1 = Y1;
      RY2 = Y2;
      myRectangle.geometricBounds = [RY1, RX1, RY2, RX2];
      SX1 = RX2+2.5;
      SX2 = X2;
      SY1 = Y1;
      SY2 = Y2;
      var mySecondRectangle = myDoc.rectangles.add({geometricBounds:[SY1, SX1, SY2, SX2]});
      mySecondRectangle.fillColor = myDoc.swatches.item("None");
      mySecondRectangle.contents = contents.image;
        • 1. Re: Create graphics frame with an "X"
          csm_phil Level 4
          Hi Matteo,
          i have edited your js code:
          i think you expect this?
          RX1 = X1;
          RY1 = Y1;
          RY2 = Y2;
          SX1 = RX2+2.5;
          SX2 = X2;
          SY1 = Y1;
          SY2 = Y2;
          var mySecondRectangle = myDoc.rectangles.add({geometricBounds:[SY1, SX1, SY2, SX2], contentType:ContentType.GRAPHIC_TYPE});
          thx
          csm_phil
          • 2. Re: Create graphics frame with an "X"
            maphiom Level 1
            That's exactly what I expected. Thanks, csm_phil!
            I ended up putting everything in one line, doesn't run much faster, but at least it's neat
            var myPetitFrere = myDoc.rectangles.add({geometricBounds:[SY1, SX1, SY2, SX2], contentType:ContentType.GRAPHIC_TYPE, fillColor:myDoc.swatches.item("None"), strokeWeight:0});
