5 Replies Latest reply on Jun 1, 2011 12:52 AM by naval joshi
    not getting the object refrence from event listner
    naval joshi
      public function category(e:MouseEvent):void
      trace((IVisualElement(e.currentTarget)));
      //here i want to get button.label.text...
      //but i m not geeting the button reference..
      Code:
      i have no idea how to reach the clicked button properties from the listner...
      i have a simple as3 component say button and a label on it...
      i create 5 buttons from the mxml file looping the objects...now wat i want is when i click on any button i should get its label back..the label is uniqe...
        • 1. Re: not getting the object refrence from event listner
          Claudiu Ursica Level 4
          Can you paste your code?
          C
          • 2. Re: not getting the object refrence from event listner
            naval joshi Level 1
            package Components
                 import flash.events.Event;
                 import flash.events.MouseEvent;
                 import flash.net.FileReference;
                 import mx.controls.Alert;
                 import mx.controls.Button;
                 import spark.components.BorderContainer;
                 import spark.components.Button;
                 import spark.components.Image;
                 import spark.components.Label;
                 import spark.components.Panel;
                 import spark.components.TextInput;
                 public class Category extends BorderContainer
                      public function Category()
                           super();
                           height=50;
                           width=220;
                           //code for image in the category component
                           i.height=40;
                           i.width=100;
                           i.x=0;
                           i.y=0;
                           addElement(i);
                           //code for labe in category component
                           l.height=45;
                           l.width=130;
                           l.x=100;
                           l.y=10;
                           addElement(l);
                 public static  var sta:Number=0;
                 public var i:Image= new Image;
                 public var l:Label= new Label;
            this is my component which i m calling
            in the mxml file im doing
                 public var cb:Category=new Category;
                    cb.addEventListener(MouseEvent.CLICK,category);
                                //trace(AS3.e.cb.l.text);
                                //trace((IVisualElement(IVisualElement(e.currentTarget)));
                                     //trace(((IVisualElement(e.currentTarget)).AS3).cb.);
                                     //flag=0;
            i am trying to get the label property of the componet...
            • 3. Re: not getting the object refrence from event listner
              I run your code as follows
              package
                      public static var sta:Number = 0;
                      public var i:Image;
                      public var l:Label;
                          super();
                          width = 220;
                          height = 50;
                      override protected function createChildren():void
                          super.createChildren();
                          i = new Image();
                          i.height=40;
                          i.width=100;
                          addElement(i);
                          l = new Label();
                          l.height=45;
                          l.width=130;
                          l.x=100;
                          l.y=10;
                          addElement(l);
              Main app
              <s:Application
                  xmlns:fx="http://ns.adobe.com/mxml/2009"
                  xmlns:mx="library://ns.adobe.com/flex/mx"
                  minWidth="955"
                  minHeight="600"
                  creationComplete="application1_creationCompleteHandler(event)">
                  <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                  </fx:Declarations>
                  <fx:Script>
                      <![CDATA[
                          import mx.events.FlexEvent;
                          public var cb:Category = new Category();
                          protected function application1_creationCompleteHandler(event:FlexEvent):void
                              addElement(cb);
                              cb.addEventListener(MouseEvent.CLICK, category);
                              //flag=0;
                  </fx:Script>
              </s:Application>
              A breakpoint in the category handler shows the category as current target.
              Are you adding cb on the display list in your code?
              C
              • 4. Re: not getting the object refrence from event listner
                naval joshi Level 1
                yes cb is added to the stage...n when clicked i need to retrive its label......
                basically wat i m trying is to get all the properties of the object the event has been fired..
                • 5. found the solution...thanks for replying!
                  naval joshi Level 1
                  public function handleCategoryClicked(event:MouseEvent):void
                  var clickedButton:Button = event.currentTarget as Button;
                  trace(clickedButton.label);
