4 Replies Latest reply on Jun 7, 2011 6:58 PM by talaya white
    Text Wrap Question
    cwells10
      I have a document that has a semi circle graphic in the center.  I have two articles on the page, one outside the semi-circle and one inside.  I have been able to get one side(text box) to follow the contour of the semi-circle but not the other. Any help would be appreciated.
        • 1. Re: Text Wrap Question
          Looks like the frame on the left needs to be wider...
          • 2. Re: Text Wrap Question
            cwells10 Level 1
            I have made it wider but the text wrap assigned to the semi-circle (detect edges) doesn't pick it up.  The text wrap on the semi circle is set to wrap around obect shape - detect edges, invert.  If I remove the invert then I lose all of the text inside the semi-cirlecurve-page.jpg
            • 3. Re: Text Wrap Question
              Perhaps you should show us some frame edges and explain how you've built this.
              I would make the yellow stroke an independent object and apply the wrap to that, selecting largest area for where to wrap, I think. You cannot wrap to both the inside and outside of a closed shape, but you could make the green area on the right a text frame and the text would naturally follow the contour, then add the wrap to that frame to push away the text on the left.
              • 4. Re: Text Wrap Question
                talaya white Level 1
                I'd make the right hand text box actually curved, and make that curved text box with an external textwrap to push the box on the left.
                Like this:
                You'll need to turn textwrap on for the boxes that you don't want effected too, like your header and the names of the officers.
