1 Reply Latest reply on Jul 27, 2011 1:49 PM by JAXIMFLASH
    Using Flash Builder 4.5 to develop for Air for TV?
    JAXIMFLASH Level 1
      How can I target Adobe Air 2.5 when using Flash Builder 4.5 so I develop for Adobe Air for TV?
      When I change the app.xml file to point to 2.5, I get the following error:
      "Namespace 2.5.0 in the application descriptor file should be equal or higher than the minimum version 2.6.0 required by Flex SDK."
        • 1. Re: Using Flash Builder 4.5 to develop for Air for TV?
          JAXIMFLASH Level 1
          I was finally able to get my app on a Samsung TV. Here's some more info on this subject. You actually have to overlay the Air 2.6 SDK - not the 2.5 SDK.
          Also make sure when you finally package the TV app to change the application XML to point to 2.5,. During development you can leave it as 2.6.
          @see http://learn.adobe.com/wiki/display/airquestions/AIR+for+TV
          What tools do developers use to create AIR 2.5.1 apps for TVs?
          Developers can use the following tools:
          Note: Developers can use the AIR 2.6 SDK for developing apps for AIR 2.5.1 for TV. In Flash Professional, set the publish settings to Adobe AIR 2.5. In Flash Builder, set the AIR namespace to 2.5 in the app descriptor file:
          <application xmlns="http://ns.adobe.com/air/application/2.5">.
          If you are using Flash Builder 4.5, you must do the following:
          1. Download the Flex 4.1.0.16076 SDK.
          2. Download the AIR 2.6 SDK.
          3. Copy each file from the AIR 2.6 SDK into the corresponding directory within the Flex 4.1 SDK, replacing the Flex original variants.
          4. To use this SDK within Flash Builder, select your project in the Flash Builder package explorer.
          5. Choose Project > Properties to open the project's Properties dialog box.
          6. Select Flex Compiler in the list and then click the "Configure Flex SDKs" link to open the Preferences dialog box.
          7. Click the Add button, browse to the SDK, and then click OK until you get back to the project's Properties dialog box.
          8. Click the "Use a specific SDK" option and then pick Flex 4.1 from the drop-down menu.
          You must also replace the default WindowedApplication element with Application in your project's MXML file.
