1 Reply Latest reply on May 31, 2011 5:34 PM by Ned Murphy
    Need help on multiple fla projects
    hlai_2011
      I am new flash developer, and inherited a project which has 4 fla project files. When it runs inside a browser, it appears "window" which occupies whole browser. This project is write in Flash CS3.
      I have few questions:
      1). When loading main swf file, 3 other swf files are also loaded. These swf files are communicating with each other through message. When debug the mail swf with CS3, I can set breakpoint and the program can stop only at limited AS files.
      My questions is how to debug other AS files in other swf file?
      2) I used CS5. It seems that I can stop at more AS files, which does not belong to main swf file. Why?
      My questions is should I use CS5, which might makes debugging easier? Is it right direction to go to debug multiple swf?
      (For CS5, I need to fix some code in order to make the program fully working as CS3)
      3) What's best tool to use for such project since CS3 is very old. Should I use Flash builder, Flex. Amethyst?
      Thank you very much.
