4 Replies Latest reply on Jun 2, 2011 11:00 AM by Jerry62712
    Debugger URL?
    Jerry62712 Level 1
      Having spent too much time on it, what is the location of the Flash Player Debugger for Firefox 4?
        • 1. Re: Debugger URL?
          Jerry62712 Level 1
          More info:
          According to the Adobe "Find Flash Player Version" (http://kb2.adobe.com/cps/155/tn_15507.html), I have the debugging version installed.  But when I try to enter the debug mode under Flex 3 (yes, there is a reason I have to use the old version for this application at this time), it says there is no debugger installed.
          I'm using Firefox 4 and Flash Player 10.3.181.14.
          I want to debug it because when I change state within a component nothing is changing.  I recently took the input form and made it a component.  I also took the result form and made it one as well.
          • 2. Re: Debugger URL?
            Flex harUI Adobe Employee
            Make sure the browser that gets launched in debug mode is the same one you
            used to test the version.
            • 3. Re: Debugger URL?
              Jerry62712 Level 1
              In both cases it is FF4.  A bigger problem just popped up (new thread) that has to be resolved first as I can't get past the error.  Sigh.
              Here is the message for this problem:
              C:\WINDOWS\system32\Macromed\Flash\Flash10n.ocx
              Flex Builder cannot locate the required debugger version of Flash Player. You might need to install the debugger version of Flash Player 9 or reinstall Flex Builder.
              Do you want to try to debug with the current version?
              I can't find a place in Flex Builder where you specify the Flash Player version.  I've got 10.
              • 4. Re: Debugger URL?
                Jerry62712 Level 1
                As usual, you had the right of it.
                KUDOS yet again.
