1 Reply Latest reply on Jun 4, 2011 10:46 PM by talofer99
    problem with multiple cffile upload.
    cfsetNewbie Level 1
      Hello;
      I am trying to program a small manager that will allow someone to upload 3 files, an image, pdf, and vcf files. I don't get any errors, BUT when I upload, the pdf file writes in as true to the db, it does upload the file, but I can't figure out why It's writting true and not the file name. I think I only need anothe rpair of eyes.. I can't figure it out. Can anyone help me out, and maybe see what I missed? I'll put in the form fields from the edit page and the query for the upload. So you get the idea.
      Edit page:
      <cfform action="Action.cfm" method="post" name="projects" id="projects" enctype="multipart/form-data">
      <cfif isDefined("URL.ID")>
          <cfinput type="hidden" name="ID" value="#variables.ProjectID#">
          <cfinput type="hidden" name="oldimage" value="#MYFile#">
          <cfinput type="hidden" name="oldPDF" value="#MYPdf#">
          <cfinput type="hidden" name="oldVCF" value="#MYVfile#">
        </cfif>
      <cfinput type="file" name="MYFile" id="MYFile">
      <cfinput name="MYPdf" type="file" id="MYPdf">
      <cfinput name="MYVfile" type="file" id="MYVfile">
      </cfform>
      Action Page:
      <!--- set file uploading vars --->
      <cfparam name="fileuploaded" type="boolean" default="false">
      <cfparam name="uploadedfile" default="">
      <cfset pathToFile = "c:\websites\215296Kh8\images\contentfile\">
      <cfif len(trim(form.MYFile))><!--- if a file has been selected --->
      <!--- try uploading new file --->
      <cftry>
      <cffile Action="upload" filefield="MYFile" accept="image/gif,
      image/jpg, image/jpeg, image/pjpeg"
      destination="#pathToFile#" nameconflict="MAKEUNIQUE">
      <cfset fileuploaded = true>
      <cfset uploadedfile = cffile.serverfile>
      <cfcatch type="any">
      <!--- if upload did not suceed, reset file uploading vars --->
      <cfset fileuploaded = false>
      <cfset uploadedfile = "">
      </cfcatch>
      </cftry>
      </cfif>
      <cfparam name="PDFfileuploaded" type="boolean" default="false">
      <cfparam name="PDFUploadedfile" default="">
      <cfif len(trim(form.MYPdf))><!--- if a file has been selected --->
      <cftry>
      <cffile Action="upload" filefield="MYPdf" accept="application/pdf, application/msword" destination="#pathToFile#" nameconflict="MAKEUNIQUE">
      <cfset PDFfileuploaded = true>
      <cfset PDFUploadedfile = cffile.serverfile>
      <cfset PDFfileuploaded = false>
      <cfset PDFUploadedfile = "">
      </cfcatch>
      </cftry>
      </cfif>
      <cfparam name="VCFfileuploaded" type="boolean" default="false">
      <cfparam name="VCFUploadedfile" default="">
      <cfif len(trim(form.MYVfile))><!--- if a file has been selected --->
      <cftry>
      <cffile Action="upload" filefield="MYVfile" accept="text/x-vcard, application/vcard (Macintosh only), text/anytext, text/directory, application/x-versit (Eudora Plug-in), text/x-versit (Eudora Plug-in), text/x-vcalendar" destination="#pathToFile#" nameconflict="MAKEUNIQUE">
      <cfset VCFfileuploaded = true>
      <cfset VCFUploadedfile = cffile.serverfile>
      <cfset VCFfileuploaded = false>
      <cfset VCFUploadedfile = "">
      </cfcatch>
      </cftry>
      </cfif>
      <cfif form.id gt 0><!--- updating an existing record --->
      <!--- if new file upload was successful and the feature has an file
      associated with it - delete old file --->
      <cfif fileuploaded is true AND len(trim(form.oldimage))>
      <cfif FileExists(pathToFile & form.oldimage)>
      <cffile action="delete" file="#pathToFile & form.oldimage#">
      </cfif>
      </cfif>
      <cfif PDFfileuploaded is true AND len(trim(form.oldPDF))>
      <cfif FileExists(pathToFile & form.oldPDF)>
      <cffile action="delete" file="#pathToFile & form.oldPDF#">
      </cfif>
      </cfif>
      <cfif VCFfileuploaded is true AND len(trim(form.oldVCF))>
      <cfif FileExists(pathToFile & form.oldVCF)>
      <cffile action="delete" file="#pathToFile & form.oldVCF#">
      </cfif>
      </cfif>
      <cfquery name="UpdateDetails" datasource="#APPLICATION.dataSource#">
      UPDATE Projects
      SET
      <cfif fileuploaded is true>
      Projects.MYFile=<cfqueryparam cfsqltype="cf_sql_varchar" value="#uploadedfile#">,
      </cfif>
      Projects.mainPhone=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.mainPhone#">,
      <cfif PDFfileuploaded is true>
      Projects.MYPdf=<cfqueryparam cfsqltype="cf_sql_varchar" value="#PDFfileuploaded#">,
      </cfif>
      Projects.mainEmail=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.mainEmail#">,
      <cfif VCFfileuploaded is true>
      Projects.MYVfile=<cfqueryparam cfsqltype="cf_sql_varchar" value="#VCFfileuploaded#">,
      </cfif>
      Projects.position=<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.position#">,
      Projects.Body=<cfqueryparam cfsqltype="cf_sql_longvarchar" value="#form.PDSeditor#">,
      Projects.CategoryID=<cfqueryparam value="#form.CategoryID#" cfsqlType="CF_SQL_INTEGER">
      WHERE ProjectID = <cfqueryparam value="#form.ID#" cfsqlType="CF_SQL_INTEGER">
      </cfquery>
      <cflocation url="part-manager.cfm?ID=#Form.ID#" addtoken="no">
      <cfelse>
      <cfquery name="InsertDetails" datasource="#APPLICATION.dataSource#">
          INSERT INTO Projects
      (MYFile, mainPhone, MYPdf, mainEmail, MYVfile, position, Body, CategoryID)
      VALUES
      (<cfqueryparam cfsqltype="cf_sql_varchar" value="#uploadedfile#" null="#NOT fileuploaded#">,
      <cfqueryparam cfsqltype="cf_sql_varchar" value="#PDFUploadedfile#" null="#NOT PDFfileuploaded#">,
      <cfqueryparam cfsqltype="cf_sql_varchar" value="#VCFUploadedfile#" null="#NOT VCFfileuploaded#">,
      <cfqueryparam value="#form.CategoryID#" cfsqlType="CF_SQL_INTEGER">)
      </cfquery>
      <cfquery name="qFetchID" datasource="#APPLICATION.dataSource#">
           SELECT id
           FROM Projects
           WHERE mainEmail =<cfqueryparam cfsqltype="cf_sql_varchar" value="#form.mainEmail#">
      </cfquery>
      <cflocation url="part-manager.cfm?id=#qFetchID.id#" addtoken="no">
      </cfif>
      I'm sorry it's so much code.. I commented it out a little so you can see what I'm doing... It's just writting to the database improperly on both the update and insert.
      Thank you.
        • 1. Re: problem with multiple cffile upload.
          talofer99 Level 2
          You have this (LOOK AT THE BOLD LETTERS) :
          </cfif>
          instead of
          Projects.MYPdf=<cfqueryparam cfsqltype="cf_sql_varchar" value="#PDFUploadedfile#">,
          </cfif>
          maybe try to use less confusing names like :
          PDF_UploadedfileName
          AND
          PDF_FileUploaded_YN
