1. Re: How To Close an Excel File?
-==cfSearching==- Jun 1, 2011 2:02 PM (in response to Dan Bracuk)This will crash, saying that TheWorkbook does not have a close method.
TheWorkbook.Close(CreateObject("java","java.io.FileOutputStream").init (TheFileJava));
Right, because the code is calling XSSFWorkbook.close() instead of FileOutputStream.close(). Use workbook.write() to copy the data into your outputstream first, then close() it.
TheOutputStream= CreateObject("java","java.io.FileOutputStream").init(TheFileJava);
TheWorkbook.write(TheOutputStream);
TheOutputStream.close();
TheWorkbook = CreateObject("java","org.apache.poi.xssf.usermodel.XSSFWorkbook").Ini t(CreateObject("java","java.io.FileInputStream").Init(TheFileJava));
Though it works, you should not need a FileInputStream. Give it a try with just the file path. The same goes for FileOutputStream.init()
Message was edited by: -==cfSearching==-
2. Re: How To Close an Excel File?
Dan Bracuk Jun 1, 2011 3:58 PM (in response to -==cfSearching==-)Thank you for the reply.
When I ran this:
TheFileCF = ExpandPath( "./dan2.xlsx" );
TheFileJava = CreateObject("java","java.io.File").Init(TheFileCF);
).Init(
CreateObject("java","java.io.FileInputStream").Init(TheFileJava));TheOutputStream= CreateObject("java","java.io.FileOutputStream").init(TheFileJava);
TheWorkBook.Write(TheOutputStream);
TheOutputStream.Close();The page ran without error. I was able to open the file in Excel afterwards but could not save changes. The dialogue said that the file was still in use.
I'll keep slogging away.
3. Re: How To Close an Excel File?
Adam Cameron. Jun 1, 2011 4:03 PM (in response to Dan Bracuk)Is it because you've opened a FileInputStream but not closed it?
(just a guess).
Adam
4. Re: How To Close an Excel File?
-==cfSearching==- Jun 1, 2011 6:46 PM (in response to Dan Bracuk)I ran the code under CF9 and the resulting file was not locked. You might try a different file/name just to make sure the lock was not left over from a previous failed attempt. That has happened to me before.
You should not need to close the FileInputStream, but doing so should not hurt either. So you may as well give that a try too.
-Leigh
5. Re: How To Close an Excel File?
Dan Bracuk Jun 1, 2011 7:11 PM (in response to -==cfSearching==-)First, I should have mentioned it earlier, but my quest for info led me to cfsearching's blog. Also, I have finally finished the easy part with this code.
TheFileCF = ExpandPath( "./dan.xlsx" );
TheInputStream = CreateObject("java","java.io.FileInputStream").init(TheFileJava);TheWorkbook = CreateObject("java","org.apache.poi.xssf.usermodel.XSSFWorkbook").Init(TheInputStream);
TheInputStream.Close();
TheOutputStream= CreateObject("java","java.io.FileOutputStream").init(TheFileJava);TheWorkBook.Write(TheOutputStream);
TheOutputStream.close();All answers were helpful. All seemed to be correct, to the extent that I understand what was happening. It seemed that once I coded myself into trouble, a 20 minute rest would time out the session and release the files.
Thank you Adam and cfsearching. I take back half the bad things I have said about each of you.
6. Re: How To Close an Excel File?
-==cfSearching==- Jun 1, 2011 7:50 PM (in response to Dan Bracuk)TheInputStream.Close();
Odd. I ran your code several times and it works perfectly without closing the inputstream. In fact I almost never do that for inputstreams. Even POI's examples do not use it. Output streams are another story. But like I said, using it certainly will not hurt.
As long as we are not under any similar obligations ;-)
7. Re: How To Close an Excel File?
Adam Cameron. Jun 1, 2011 11:04 PM (in response to Dan Bracuk)Thank you Adam and cfsearching. I take back half the bad things I have said about each of you.
Most of them are probably true though ;-)
Adam
8. Re: How To Close an Excel File?
-==cfSearching==- Jun 2, 2011 9:53 AM (in response to Adam Cameron.)Thank you Adam and cfsearching. I take back half the
.. maybe half of them
9. Re: How To Close an Excel File?
Adam Cameron. Jun 2, 2011 10:35 AM (in response to -==cfSearching==-)The half that are about you...
10. Re: How To Close an Excel File?
-==cfSearching==- Jun 2, 2011 2:59 PM (in response to Adam Cameron.)The half that are about you...
You read my mind .. or my last post
